Old 03-21-2005, 08:57 PM
acoustic-sounds acoustic-sounds is offline
Fuel Pressure Relief-98 Eclipse RS
How would I go about relieving the fuel pressure on my 1998 Eclipse RS. I cant start my car to let the fuel run out any-other ways.
Old 03-21-2005, 09:07 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Fuel Pressure Relief-98 Eclipse RS
unscrew the gas cap to releive any pressure in the tank. and there should be a schrader valve on the fuel rail to hook up a guage or whatever. just take off the cap and press the button inside. a little gas will squirt out and then you'll be good.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 03-22-2005, 08:18 PM
dsmodder dsmodder is offline
Send a message via AIM to dsmodder
i usually just unscrew gas cap and unplug fuel pump. then start car and let it die.
