Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-21-2005, 08:52 PM
brock_rick brock_rick is offline
injectors not opening
I'm trying to bring a 1991 honda crx back to life , Its been striped of parts. I have got power to the ecu. Its flashing 6,7,8,9,10,13,20. I have spark at the spark plugs. Getting fuel to the fuel rail, But it will not start. I have put gas in each spark plug hole, and it will fire up but shut s off. I think the injectors are not opening because the plugs are dry after cranking the engine over. I've checked the injector resistor, that checks out ok. There is 12 volt getting to the injectors.The ohms check out on the injectors to. I have taken out each injector and put a jumper wire on the injector to open it ,and shot air though the injector to see if the injector are pluged. That checked ok. Please help
Old 03-22-2005, 09:28 PM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
Re: injectors not opening
What are the codes descriptions? fuel pressure? Timing?
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Old 03-22-2005, 10:19 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
so get a friend with the same car, and try his injectors
