Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 03-21-2005, 08:39 PM
batman19 batman19 is offline
Send a message via AIM to batman19
Fuel Filter fuel line
I have a 94 v6 z body 4wd sonoma
I took it to the shop to change my fuel filter(i tried a few time and cant get it out) but they told me is in too bad condition to change my fuel filter. They suggest me to change the fuel line along with the fuel filter, cus they will pretty sure will break them when they are try to get the filter out.
First does anyone know how to change the fuel filter from tank to engine?
If u done it b4, is it a bitch work or pice of cake? How much is the fuel line itself?
Old 03-31-2005, 06:45 PM
bump, does anyone know?
1997 Civic HX
1.6 D16Y5 engine
Auto with 55K
STOCK
Old 04-01-2005, 07:02 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Fuel Filter fuel line
Drop the tank, unbolt the line, put new line in, bolt back..Should take you about 2 hours. And remember to use line wrenches!
Old 04-04-2005, 09:50 PM
where can i get the fuel line?
1997 Civic HX
1.6 D16Y5 engine
Auto with 55K
STOCK
Old 04-05-2005, 05:20 AM
rlith's Avatar
Re: Re: Fuel Filter fuel line
Unless you have the proper tools to bend and flare line, you need to buy the lines from the dealer. Get both the main feed and the return line.
Old 04-05-2005, 05:52 PM
have anyone use a line wrench to get a fuel filter off b4? remember i have the older style
1997 Civic HX
1.6 D16Y5 engine
Auto with 55K
STOCK
Old 04-05-2005, 06:04 PM
rlith's Avatar
You should ALWAYS use a line wrench when dealing with fuel lines. It sucks to strip those things.
Old 04-16-2005, 06:59 AM
rlith's Avatar
So what was the verdict?
Old 03-05-2006, 08:58 AM
fattcatt8006 fattcatt8006 is offline
i just did a fuel filter on my 92 sonoma it was not a 2 hour project it was a five hour night mear and you dont need line wrenches yea their nice but you can use a nice set of wrenches and it will get the job done. The lines on it are rusted but unless their leaking dont mess with them. The steel line is around 4.89 dollars for five feet and for rubber high pressure its is around 4.88 dollars a FOOT you dont need a pipe bender just use your hands it works just fine.
Old 06-15-2007, 08:41 AM
rayh059 rayh059 is offline
Ok, its an old post, but I have the same issue.
Hey batman, how did you make out?
My lines leak, so I'm in the process of lifting the bed off to replace the lines and the sending unit, shocks and clean up/paint underneath. I have the blues of dealing with tubing.
1994 Sonoma Extended Cab 4x4 Auto SLS
code "Z" Black ~130K Miles Stock
Closed Thread
