Go Back   Automotive Forums Car Chat > Fabrication & Tools > Fiberglassing
Fiberglassing Fiberglasssing explained and the proper techniques on working on a fiberglass project.
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 03-21-2005, 08:22 PM
Powerefx Powerefx is offline
Fender flares
Does anyone have an idea on how to make fender flares? This is wut i was thinking of doing, could it be right or is it wrong --> I was gonna mask tape the area around the tires and get that upside down u shape that the fender flares have. Then i was thinking of applying more and more layers of glass until the fender flare becomes like a 3d u shaped box. After just going to sand it down to the shape i like. Does this sound good. Is there another way it could be done?
Old 03-21-2005, 08:43 PM
Rod&Custom's Avatar
Rod&Custom Rod&Custom is offline
Send a message via Yahoo to Rod&Custom
I am pretty sure that you will want to form a piece of foam in the correct shape, and then glass it, but I am not a fiberglass guy either. May I ask why you can't find any? Bush Whacker(I think) makes a wide variety of flares for most all trucks made.
Old 03-21-2005, 09:05 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Fender flares
Grants on the right track. The usual process to making flares is building a foam mold on the body then glassing over that.
-Mike
Old 03-22-2005, 06:51 PM
Re: Fender flares
Well the flares gonna go on a car, not like those on a truck, ive searched around alot and havent found any. I was wondering how to go about doing the foam thing. Can someone explain what kind of foam i should get and from where. And exactlly how i should go about glassing it. Thnx fellas.
Old 03-22-2005, 07:17 PM
mike@af's Avatar
Re: Fender flares
What in the world do you drive that you cant find parts for? Use polyurethane foam. Im not a glass expert, so talk to TSC.
-Mike
Old 03-30-2005, 07:38 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Fender flares
I use blue insulating foam that is available at places such as home depot and lowes. Sells for around $10 for a 4'x8x1/2" sheet. You'll basically want to carve out the shape that you want like mentioned above, cover it in foil, then fiberglass over that. Getting them all to match is the tricky part. Taking alot of measurments and using a profile/contour gauge is the way I do it, it takes some time and effort though.
Old 04-13-2005, 03:33 AM
yukonharry yukonharry is offline
The easiest and cheapest way by far to build the flairs you want is to get a pait of Volkswagon fenders and cut off the size you want. Place them where you want, draw a line to where you want them to be attached to. Cut out approx 1" below the line, cut tab like pieces in the 1", bend the tabs up and attach them to the fender by welding/brazing/adhisive. Blend in the edges with tiger hair, then a light coat of bondo. To correctly do it, make a piece that will attach your inner fender well to the outer fender. It will take about a day to complete it.
Old 04-16-2005, 09:28 PM
Re: Fender flares
Hey TSC can i also use the foam boards they sell at art stores for projects like michaels, staples and office depot and glass over that, or does it need to be an insulating foam board used for construction?
Old 04-17-2005, 10:23 AM
Forunn Daberator
Re: Fender flares
You can use either, make sure to cover it in foil though.
Old 04-17-2005, 11:03 AM
mike@af's Avatar
Re: Re: Fender flares
Some of that melts. Like the blue and pink stuff. Look at the details of the foam, if its called polystyrene chances are it will melt.
-Mike
Old 04-17-2005, 12:29 PM
Forunn Daberator
Re: Fender flares
Thats what the foil is for.
Old 04-17-2005, 02:42 PM
Re: Fender flares
SO i should carve the shape out the foam, cover it in foil, lay down allitle resin, put down the fiberglass, resin, fiberglass, resin...... and then sand the fiberglass, bondo and then sand the bondo. Is this right? And how many layers of glass should i use?
Old 04-17-2005, 03:14 PM
Forunn Daberator
Re: Fender flares
You should be able to do it without filler (bondo). How many layers depend on what kind of fiberglass you use. If you use the typical hardware/parts store cloth and matt then I would recomend three layers of matt on the bottom followed by two layers of cloth on top. The matt provides most of the strength and the cloth is easyer to sand.
Old 04-27-2005, 11:56 AM
Oscuro Oscuro is offline
Send a message via MSN to Oscuro
*blinks* Crap, there goes my thoughts of how to make flares for my car...I mean, I would need rather large pieces of foam....bloody hell. I might as well find a shop that could do it.
*coughs* For referance:
Vauxhall version of my car from 1980s.
Identify the car and you get my awe
Either way, trying to replicate those fenders to my car would be a massive pain in the ass....but I might try it someday.
Old 04-30-2005, 07:27 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Fender flares
2 door Citation!!!!
95 Talon TSI AWD
97 Eclipse GST
Closed Thread
