Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 03-21-2005, 08:19 PM
timmay316 timmay316 is offline
cat rasp
Hey. I just installed a custom exhaust (Xpipe after the cats and straight pipes all the way back) on my 1990 V6 bird. It really sounds good and loud, except for the little bit of rasp I get when the car is in the mid Rpm range. Im positive this rasp is coming from the catalytic converter heat shields. Is there any way I could fix this rasp with out replacing the cats?
Old 03-21-2005, 09:24 PM
JR Tigerstar's Avatar
JR Tigerstar JR Tigerstar is offline
Re: cat rasp
Sure, remove the heat shields.
Old 03-21-2005, 09:31 PM
Yes, I thought about this lol. But arent they spot-welded on? If not, how are they connected?
Old 03-21-2005, 09:40 PM
Also, if I am able to remove the cat heat shields, will this cause an emissions problem?
Old 03-21-2005, 10:03 PM
Re: cat rasp
Yeah, they're usually just spot welded. You can use a pair of tin snipes or a pair of wire cutters.
I would think not. The sheilds are external only and shouldn't affect the operation of the cats.
Old 03-22-2005, 04:50 PM
Mike75 Mike75 is offline
Re: cat rasp
I was cosidering the same course of action to get rid of my rasp. But don't you think this will get the inside hot as hell?
Old 03-22-2005, 06:17 PM
yea, I considered the same problem, overheating. Will the excess heat caused by removing the cats cause any problems? Anyone know?
Old 03-22-2005, 06:22 PM
***removing the cat heat shields, not the cats themselves, sorry
Old 03-23-2005, 07:33 PM
anyone know? (see former post)
