Old 03-21-2005, 07:34 PM
Jackinthebox3181 Jackinthebox3181 is offline
drivers side connector b16 swap
Im doing a b16 swap into my 89 crx si, and have run into a problem. Ive researched for hours and cant find an answer, and im hoping someone that has done this swap can help me. There is a driver side connector that has come off the b16 engine that does not plug into the stock crx connector on that same side. It is the connector that also has wires going into the resistor box. I was wondering what is supposed to be done with this connector to make it work. Also, if anyone knows, does the knock sensor have to be hooked up in order for the car to have spark. Thanks in advance for everyones help.
Old 03-21-2005, 10:14 PM
Hybrid1990crx's Avatar
Re: drivers side connector b16 swap
are you trying to use the harness that came with the b16? If so, its useless. You need to use the one from your stock motor.
