Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 03-21-2005, 06:27 PM
ruberpoliceman ruberpoliceman is offline
Starter problems
the starter on my 1986 caprice is acting strange. when i first start it up it turns over fine but when i let it run for a while, cut it off, and start it again it turns over slow like the battery is dead. what could be wrong?
Old 03-26-2005, 08:20 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: Starter problems
If you let it sit for a while (few hours) after shutting it off does it start slow as well? If so, you might have a bad altenator, but it sounds kinda wierd (It should be the other way around). Your starter might possibly need a rebuild.
Old 03-29-2005, 08:21 AM
ok, thanks
Old 03-29-2005, 07:51 PM
CD Smalley CD Smalley is offline
Sounds like the starter is suffering from heat soak. Probably time for a new one..
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 03-29-2005, 11:30 PM
burnM's Avatar
burnM burnM is offline
Sounds similar to a problem I had with my '85 and my old '83. Check the small ground wire that goes from the battery to the fender. Sometimes the 10mm bolt works its way loose and causes a slow drain. Do you make a lot of short trips? The alternator can't recharge the battery too efficiently with a slow drain and short trips.
1977 GMC Jimmy - daily driver-sitting on 33's and bedliner inside and out
1995 9C1 Caprice - winter beater
1994 Impala SS - newest project
1991 9C1 Caprice - (rip)
"There are two great problems in the world today; an ever-growing lack of common sense, and too many warning labels. Take away all of the warning labels and the problem will work itself out..." -B
Old 03-31-2005, 06:28 PM
aight, thanks all..
