Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 2nd Gen 00-05
Old 03-21-2005, 06:16 PM
00DodgeMan 00DodgeMan is offline
Send a message via AIM to 00DodgeMan
No Tach instructions have helped me
Im trying to put a Sunpro tach in my 00 dodge neon, and everythings all hooker up, the only problem is that the RPMs are about half of what they should be. I checked their website, and they didnt say that i needed an adapter, but I dont know what else to do.
The tach wire from the tach is connected to 1 of the 3 wires coming from the 1 cluster from my distributor cap. Ive tried all three wires.
If anyone can help, thatd be great.
Old 03-21-2005, 06:36 PM
nickelfish19's Avatar
nickelfish19 nickelfish19 is offline
Send a message via AIM to nickelfish19 Send a message via MSN to nickelfish19 Send a message via Yahoo to nickelfish19
Re: No Tach instructions have helped me
there is a switch on the back has setting for 4, 6, 8 cylinders. if it is set on eight it would make sense that it would divide your signal in half.
2005 cavalier 2.2 ecotec, getrag 5 speed, razzi kit.
http://www.cardomain.com/id/nickelfish19
Old 03-21-2005, 06:38 PM
Re: Re: No Tach instructions have helped me
sorry i forgot to mention, Ive tried all three settings, and my Idle RPM goes from about 200 on 8, to maybe 500 on 4. thanks though
Old 03-22-2005, 05:59 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
try the neon forums there smart one..
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 03-22-2005, 11:15 PM
KustmAce's Avatar
KustmAce KustmAce is offline
Grande Boleros de Fuego
I agree with crj, though it could have been worded a bit friendlier...
MAKE ART, NOT WAR
Old 03-28-2005, 04:16 PM
pjirsa pjirsa is offline
Half RPM Reading on Tachometer
I have an Autometer tach that I had to send back to the factory to have it adjusted for my 95 Neon. When I first hooked it up it only read 1/2 of the rpms.
Old 07-18-2007, 03:47 PM
dabuhone dabuhone is offline
the reason that the tach u bought isnt working is because there is no tach wire for a your neon if its anything like my 2001 neon, i tried to hook mine up yesterday and it did the same thing what u have it hooked up to now is the fuel injector wire so that is what its reading currently
Old 07-29-2007, 11:09 AM
denisond3 denisond3 is offline
Reason why aftermarket tachs dont read correct RPM..
I Think I Know why the tachometers only read half of the real RPM. The aftermrket tach was probably designed for a car with a distributor. In that case there would be 4 ignition 'pulses' to count per each two revolutions of a 4 cylinder engine. But the coil pack on the Neon is really two separate coils in one unit. And each coil is only fired 2 times per each two revolutions of the engine. It might be possible to connect Both of the 'signal' or 'trigger' wires going to the coil pack to the tachometer input: BUT, there would Have-To-Be a diode included in each wire - in series- to isolate the two halves of the coil pack. The diodes would let the tachometer see both pulses from both coils, thus four ignition pulses; without fouling up the signals from the PCM. (or destroying it)
Most diodes will have a painted band around the 'cathode' end. This is the side that I would run to the tachometer. The 'anode' end would be connected to the wire running to the coil pack. (If the tach didnt show anything I would reverse them.) Two 1 amp diodes would be good enough, but I would use diodes that had at least a 400 volt PIV rating: Because there would probably be a good sized inductive 'spike' on the wire to the coil pack.
For my Neon I bought via ebay.com a replacement instrument cluster with a tachometer in it. The wiring for that tach was already in the harness for my Neon - a 1997.
Old 07-30-2007, 11:13 PM
i dont think my instrument panal has a tach wire in its harness because i tested every connection with a multi-meter and had no luck finding a connection that was anything like a tach. But thanks for all ur input i am going to try and do this when i get home from vacation. i want it to work but then again id like to go to the autozone guy who sold me the tach and rub it in his face i was right and he was wrong lol
