Old 03-21-2005, 06:09 PM
WannaLearnMore WannaLearnMore is offline
Auto to Maunal
Anyone ever tried it? I've got a TH-350 tranny in my car right now that I'd like to swap out for a Richmond 6-speed. The part I'm most worried about is adding a clutch pedal, etc., and the mounts where there has never been any. Any suggestions? hints? tips? experienced input?
81 T-Top Z28
350 ci bored .060 over
Edelbrock Torquer Plus Cam, Torquer II Intake
Dart Iron Eagle 202 Heads
Edelbrock 750 Carb (jetted down just a bit to fit)
Custom Built Distributor
MSD 6AL Ignition Control Box
Summit Headers, Mufflers with 3 inch Dual Exhaust
Dual Remote Oil Filter System
Old 03-21-2005, 06:35 PM
philly rs's Avatar
philly rs philly rs is offline
Send a message via Yahoo to philly rs
Re: Auto to Maunal
let me know how that goes i have a friend who's been toying with that same idea, i cant call it myself
Your import sounds like my ass after a night of mexican food..
And spraying aint cheating, its brining a gun to a knife fight!!
yeah, its a v6 RS...never mind the f1 badges lol
HYPSI87 u will be missed
Old 03-21-2005, 11:28 PM
whoisdabomb86 whoisdabomb86 is offline
Send a message via AIM to whoisdabomb86
id stick with the th350, i got one in my 86 camaro,i personally love auto's...no clutch, just slam my shifter forward and pass the competition..ill never go to standard.
Old 03-22-2005, 10:28 AM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: Auto to Maunal
well i know a couple people that have thought about this (i personally toyed with it for a while), there have even been tv shows about it. ive gotten conflicting stories on it. most people say that its not as difficult as you would assume. the cars a designed to be either a manual or an auto so most of the stuff should be there. its certainly not a project for even the slightest novice. the best way to do it is to find a donor car, park it in the driveway, and swap parts as needed. either way its gonna cost a penny or two, but as the sayin goes: anything is possible with money...
*Better power-to-weight ratio than a C6 corvette*
Old 03-22-2005, 04:39 PM
A novice I am not when it comes to the under hood stuff, and I know it's gonna cost a pretty penny. The tranny I want alone is listed at $3100 from Summit. That's not including shipping. I'm having a difficult time finding a car like mine in a junk yard that was a standard to begin with, so I've been thinking about taking a hydraulic clutch system off a newer car, instead of the all mechanical one, and adapting it to fit mine. Hydraulic fluid lines are a lot more forgiving to work with compared to trying to perfectly align a mechanical one. I guess I'll find out eventually.
81 T-Top Z28
Old 03-23-2005, 04:57 PM
Xenostalgia's Avatar
Xenostalgia Xenostalgia is offline
Send a message via AIM to Xenostalgia
Re: Auto to Maunal
Eh give a mechanic-buddy a call and see what they say. Doesn't hurt imo.
Originally Posted by 97CamaroRS
You know he's cruisin in the GN above us - RIP, Andy
Be Warned....
Originally Posted by twospirits
what your name really means...
XENO...
Xtreme
Emotional
Neurotic
Ominous
www.Xenostalgia.com Exit your Reality || 97 Acura Integra GS 2DR
Old 03-23-2005, 05:06 PM
brass_monkey93 brass_monkey93 is offline
Re: Auto to Maunal
I know a guy that owns a tranny shop and when i asked him this same question he said that he personally wouldnt try it because you would need to cut up the console and add the clutch. but if you do it i'll give you props
future mods:
Pacesetter Headers
Magnaflow Exhaust
Jet Performance Chip
Ram air hood w/ functional air box
Old 03-23-2005, 06:51 PM
EightyZ EightyZ is offline
What year is the camaro? i have done it in my 80Z. It fun let me tell ya. You will need new break/clutch pedels. i dont know your year so either hydro line or all the linkages for mech.
let me know the year and ill for farther!
Old 03-24-2005, 10:12 AM
It's an 81, and i'm not too worried about having to cut up the console cuz i'm building a custom one anyway. And, as far as having to add in a clutch pedal, I'm doing a custom dash also, so i'll know exactly what to do to pull it out and mount the pedal easily.
81 T-Top Z28
Old 03-24-2005, 10:44 AM
Perfect. There are 4 bolts holding the pedles in, same bolts that hold the steering colum in. the the steering colum will drop a lil and you have the role the pedels out around the wires and stuff. and unless you are going to be running a hydraulic clutch you will need to find all the linkages, and a pushrod. throwout bearing and clutch fork. and tranny. obviously clutch and get a good one, better than what you think you need. i found that out the hard way. driveshaft length will prolly be different too. the tranny crossmember is the same however the mount may be different. at least it was the same from th-350 to muncie m20. oh yeah and for the linkage you will need to drill a hole in the firewall or the linkage. there is supposed to be a nipple where the hole is supposed to go, but i couldnt find it. for the linkage there is a pivot bar, and brace that attaches to the frame, and a bearing-ish thing that bolts to the motor. you will need all of that! use this diagram to hel you get everything for that. http://www.nastyz28.com/NGCC/pedals.html
you will need a bellhousing too, if you are running a lot of power and going to 1/4 compititions and they are strict. get a bulletproof. also for your own safety. i think it got it all, ill add more if i forgot something.
Old 03-24-2005, 10:46 AM
oh yeah, just a little thing but sometimes the speedo cable is on the other side on manual trannies, so you will need one that is about 6 inches longer. maybe.
