Old 03-21-2005, 05:48 PM
acoustic-sounds acoustic-sounds is offline
ac compresser Question
If I removed the AC comppressor from my 1998 Eclipse RS what belt would I use in place of the longer belt.
Old 03-21-2005, 08:34 PM
macder macder is offline
Send a message via MSN to macder
Re: ac compresser Question
Logicaly thinking, if the AC compressor is removed, there is no reason for a belt to be there. Not to sure about the 420a, but the 4g63 has 3 separate accessory belts (alternator , power steering, AC).
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 03-22-2005, 10:56 AM
space-monkey space-monkey is offline
Banned
Send a message via AIM to space-monkey
my compressor went out in my 95 420a, and i want to say its a 48... inch. but you run the belt from the crank to the alternator and the power steering, just pull realll hard to get it to slip on, and dont over rev cause itcould slip off, over rev as in 9500 rpms
Old 03-23-2005, 05:46 PM
If you were to pull a belt to get it on it would be to tight and put to much stress on the bearing.
Old 03-23-2005, 08:14 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
no, the belts run much tighter than that normally anyways. you'd have to pull on it to get it over the bearing walls but you'd still have to tighten it more.
95 Talon TSI AWD
97 Eclipse GST
Old 03-23-2005, 09:28 PM
Banned
belive me a 46 or so works, you get part of the belt on the powersteering pump and push on the pully ot make it spin and it will fall on, its snug. i just have a slightly warped crank pully from hitting a dog so when i get abouve 7000 rpms it comes off. but ive driven with it on for over a year no prob. im almost sure its a 4 rib 46. if not autozone will work with you till oyu get the irght one to fit. its not hard. my AC compressor is still on my car till i can replace it, just beltless
