Old 03-21-2005, 05:46 PM
peanut77 peanut77 is offline
96 s10 2.2l ???
im having problems with fuel pump, im only getting 5 volts at the fuel pump. traced the wire all the way back to the ecm and cheked it there and still am only reading 5 volts. when i turn the key on i hear the relay in the glove box kicking on/off but the fuel pump does nothing. i checked the fuse on the side of the dash and thats good.
what could be causing me to only get 5 volts coming out of the ecm, does that mean i have a bad ecm. could this be an issue with the oil pressure sending unit that i see alot of people talking about.
thanks for any help anyone can give me
1996 s10 2.2l automatic
Old 03-22-2005, 03:31 PM
Re: 96 s10 2.2l ???
has anyone checked the voltage in the grey wire going to the fuel pump? did you get 5 or 12 volts. in the back of the haynes manual in the wiring schematic drawing section, it shows a section showing some wires with 5 volts but now going to fuel pump. appreciate any help anyone can give me
