Old 03-21-2005, 03:11 PM
gremlin540 gremlin540 is offline
i need help on something anyone please help me
i went to get a sticker for my blazer and i didnt pass because cause of a p0785 shift/timing sol malf can someone tell me what it is and how can i fix it the truck is slow of the start some time but not all the times when i first start its it runs great takes off nice but when it warms up it takes of really slow i was reading other answers on here and everyone said it was the ignition switch my ignition is broke i can start it without useing the key could that be the reason please help me out guys
Old 03-21-2005, 05:41 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: i need help on something anyone please help me
1.) Replace the ignition switch module.
2.) Have your transmission flushed and refilled with a new tranny filter installed.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 04-20-2005, 09:00 PM
i need some more help
ok i did wat u told me still running sluggish and now i need help on that and can someone tell me why my brake lights and turn signals keep blowing fuses not the bulbs i change the fuses and they last for like 3 days then all of a sudden blow can someone tell me why
Old 04-21-2005, 07:05 PM
ricksza's Avatar
ricksza ricksza is offline
The reason the fuse blows is because there is a short to ground in the wire that goes between to brake light bulbs and the turn signal switch or the trailer harness is shorted.
Old 04-28-2005, 04:29 PM
diddy0071 diddy0071 is offline
Send a message via MSN to diddy0071
had the same problem, wasn't the ignition switch, it was the Shifting solenoid A, which is a thirty dollar part (AT THE DEALER). I got it installed and everything at the dealer, took them 10 minutes.
maybe it is the switch though, if the SES light did not go off, you need to hook up a diagnostics reader and clear the codes first. if the same code comes back up again, then I would take it to replace the A solenoid.
"I'm a jerk, not an asshole!!"
Old 04-28-2005, 11:18 PM
Re: Re: i need help on something anyone please help me
thanks man i figured it was that because i got it checked today thanx for the info but now the truck wont start could it be the fuel pump its not makeing any sounds like a buzzing noise
Old 05-06-2005, 11:00 PM
Re: Re: Re: i need help on something anyone please help me
i have another ? i need help on something else i put the new feul pump in and now my fuel gauge stays all the way to the right saying its full all the time its stuck there for some odd reason can someone tell me y its doing this
Old 05-07-2005, 05:56 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Re: Re: Re: i need help on something anyone please help me
Sounds like you bent the float arm on the sending unit when you put it back in
Old 05-07-2005, 04:45 PM
Re: Re: Re: Re: Re: i need help on something anyone please help me
i checked that out and everythings fine i got it checked out and they sed some kind of module do u know what that module would be
Old 05-22-2005, 12:20 PM
Schrade Schrade is offline
Truck wont start and gas guage staying on full? Sounds like an electrical problem on re-install. Do you hear the pump prime when you turn the key on?
Old 05-25-2005, 12:47 AM
Hey diddy0071 - you said you changed Shift Solenoid A... You sure it was bad? I had the same DTC - P0753, but it wasn't broke...
