Old 03-21-2005, 02:42 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Get rims tomorrow
Hey all. Damn, I havent been here in awhile...
Im finally getting my rims tomorrow. My friend is selling me his aftermarket 5-star rims off his old 3000gt, the tires that are on there (used), and set of 4 newer tires (1 with a hole), for $100. They're 16's, and have a silver metal finish. I havent seen them, but I cant beat the price. (The offset is the same too). Now my questions:
The 1 newer tire has a small hole. Do you think I should just get that patched up, or just buy 1 whole new tire? I dont want to have a tire failure, especially since I drive like a crazy bitch.
The second question is, do the tires have to be balanced or anything? These came off another car... are they just going to be perfect? Alignment?
I also need new back shocks (supposedly), so the rims wont stay on until I get that fixed (uneven tire wear), but I will post pics with them on. Thanks guys
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-21-2005, 08:00 PM
viet_boiiiii's Avatar
viet_boiiiii viet_boiiiii is offline
Send a message via AIM to viet_boiiiii
Re: Get rims tomorrow
If u replace that (hole) tire then i recommend u to replace the other side of the tire too. as in if that tire is gonna be in your front passanger side then replace the both front tires so u will not have a wierd setup. This happend to me when 1 of my tires were slashed, the tire store said for me to replace both tires instead of just 1.
new 2006 Scion tC - 5spd
-magnaflow catback
http://www.cardomain.com/ride/2088489
~~~R.I.P (7-2-05)~~~
1998 Eclipse Gst - 5 spd
Old 03-22-2005, 06:51 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
There is always a possibility of the plug coming out, so I would recommend replacing the tires. And make sure you follow viet boiiii's advice and replace both tires. As for the balancing, no you do not have to have them rebalanced. Balancing has nothing to do with the car. It is to make sure that the tire is balanced on the rim. Now if you get 2 new tires, you will have to have the new ones balanced, but the old ones you can just bolt on. Enjoy......And don't forget to post some pictures when you get the new rims.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
