Old 03-21-2005, 02:00 PM
MaxBURNOUT MaxBURNOUT is offline
Send a message via AIM to MaxBURNOUT
Major HP Loss... what in the &^&#*
Ok, Heres whats going on. the other day. got up to go to work and jumped in my car. cranked it up and went to work... and it drove fine. after sitting from about 9:00 - 5:00 I got off of work and jumped in it and went to go home. and I relized I had to get my car all the way into 3rd of 4th gear before I could reach 60 MPH and trying to keep it from redlining.. I use to be able to get up to 60 in 3rd as soon as I shifted in to it.. so im not sure. all I know is that I lost some power somewhere... and im not happy at all..
Max
Old 03-21-2005, 02:01 PM
Re: Major HP Loss... what in the &^&#*
If anyone has any suggestions please let me know... thanks
Old 03-21-2005, 02:19 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
sorry to say it, but you could be looking at just about anything. Could be your catalytic converter, fuel pump, fuel filter, distributor, cap, rotor. Are you getting any engine codes, is it miss firing, idleing rough?
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 03-21-2005, 02:33 PM
nfg2184 nfg2184 is offline
Maybe your E-brake was up.
-2004 Cavalier LS
Mods:
Weapon-R Short Ram, Shift Kit, Nitrous Express Wet Kit, Upper/Lower mounts.
Audio:
15" RE .SE sub to BRUTUS 1500, 6.5" RE components in the rear, Apline's in front, all to Pheonix Gold Profile, Alpine deck.
-1997 Sentra XE, 5-speed POS, commuter.
Old 03-21-2005, 02:34 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
maybe your timing jumped. could be a million things. anything else you noticed? maybe your carpet is bunched up under your gas pedal so you cant get it all the way down who knows...
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 03-21-2005, 11:58 PM
naw ... I checked the gas.. but I did notice that my car sounds deeper.. like a deeper rumble and not like a pist off weedeater... LOL
Im not really sure that all my my cylinders are fireing..
Old 03-22-2005, 06:25 AM
it would idle crazy rough if it was running on 3 cylinders.
ZC stuff
Old 03-22-2005, 11:34 AM
It does.. Is Idleing at like 1500RPMS then go down to almost 0 then maby up to 500 ... its kinda wack
Old 03-22-2005, 04:38 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
sounds like 3 cylinders - do a compression test
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 03-22-2005, 05:43 PM
How do I do that?
Old 03-22-2005, 06:05 PM
I dont think you'll find anything doing a compression test. A couple things I would check first is pull each plug wire one at a time, put a screwdriver in the end of it where the plug would go and hold the screwdriver a couple mm away from a ground (i.e. a valve cover nut). Have someone crank the engine and make sure they see spark jump from the screwdriver to the nut. Another thing id look at is like i said earlier, your timing. What motor do you have? If you dont know how to do it, ask and we'll show you how to check it.
ZC stuff
Old 03-22-2005, 06:21 PM
Icantgetno Icantgetno is offline
Max
if your not getting the speed in a gear at the RPM your used to then i suspect your clutch is shot. 4200 rpm in my car is always 70 mph (5th gear)5100 is always 80 etc... if you used to be able to get to 60 in 3rd and now you gotta get into 4th it means your engine is spinning and not transfering the power to the tires the way it used to.
Old 03-22-2005, 06:32 PM
... I just put a F($#)ing Cluch in it... AHHHH Oh well.. what can you do.. I have a d15b2... ... with a performance or racing cluch is it harder to mess them up or is it just the driver... I know for a fact that I havent dumped the cluch. but I do know that I have had to pop start the car a number of times sence the new cluch was put in.. I baught the car and it needed a cluch and it has some shorts somewhere ... so sometimes I have to get someone to push me to start it.. would that mess it up... Is there a plate where I can check the cluch for issues
Old 03-22-2005, 06:39 PM
wait, so the rpm's go up without speeding up???
ZC stuff
Old 03-22-2005, 06:43 PM
Ok... here is whats going on...
Basicly I have to shift quicker then I use to have to.. I use to able to get to 60 as soon as I shifted into 3rd and now I have to almost get it into 4th or 5th.. and if I dont shift, my car will red line.
and my car sounds deeper.. its like my car is strugling to go...
