Old 03-21-2005, 01:13 PM
alikatncsu alikatncsu is offline
need help reprogramming 95 blazer keyless entry
Please help! I need to reprogram my keyless entry for 1995 Chevy Blazer. Any help is greatly appreciated. Thanks!
Old 03-21-2005, 02:51 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: need help reprogramming 95 blazer keyless entry
check your manual, and search the forum, i seen one either here or on the s 10 forum on this subject
Old 03-21-2005, 03:46 PM
cubanlorenzo cubanlorenzo is offline
Send a message via AIM to cubanlorenzo
you have to drop the lower kick panel under neath the steering column. after you do that you will see a black box under there. towards the back of that you will see a red connector with two pins in it, use something metal to connect them, or even pliers. when you connected them your locks will cycle. with the pliers still connecting the pins together hold the lock and unlock buttons on the remote for 5 seconds, when the locks cycle again the remote is programmed. if you have more than one you have to do them one right after another without letting go of the pliers, hope this helps...
