Go Back   Automotive Forums Car Chat > Ford > Probe
Old 03-21-2005, 12:59 PM
scott91probe scott91probe is offline
blinkin 'man. shift' light...
hi,
i read in my manual that this means that there's an electrical problem in the transaxle. i haven't noticed anything out of the ordinary, but it seems every once in a while it idles fast or noisier than usual. i'm pretty broke, but am thinking about getting it checked out. any thoughts or experiences? thank you so much for any help - i'm strapped for time at the moment.
scott
Old 04-04-2005, 04:40 PM
shawnwilliams's Avatar
shawnwilliams shawnwilliams is offline
Re: blinkin 'man. shift' light...
I'm guessing its either u need a new sensor or you need your transmissions fluid changed or to be filled.
93 FORD PROBE GT
JDM manifold ported match
65mm TB
Unorthodox Underdrive Pulley
Hotshot headers
3' Exhaust all the way
No cat
Cold air intake
K&N air filter
Short throw shifter
Eibach lowering springs
FX Design Body Kit
B&M Short Shifter
Stage 3 Clutch
MX-3 Flywheel
Performace Wires and Plugs
Synthetics
Performance Rad and fan
Mild Weight Reduction
Coming this week:
Performance Heads and Cams
3 angle head job
Why does everyone have to piss on Ford.
Old 04-04-2005, 04:54 PM
Re: Re: blinkin 'man. shift' light...
thank you! i think i will go ahead and check and replace the fluid. take care
Old 04-04-2005, 09:39 PM
welcome!
93 FORD PROBE GT
65mm TB
Hotshot headers
No cat
Cold air intake
K&N air filter
Short throw shifter
FX Design Body Kit
B&M Short Shifter
Stage 3 Clutch
MX-3 Flywheel
Synthetics
Coming this week:
3 angle head job
Old 07-29-2005, 10:24 PM
lufkintravis lufkintravis is offline
Send a message via AIM to lufkintravis Send a message via Yahoo to lufkintravis
Mine too
I got in my car to back up one day (1992 LX 3.0) and the transmission just let go while the car was moving back. I didn't hear a noise or feel anything, so I thought it had died. The tach was still registering so I looked @ the shifter thinking maybe I had knocked it out of gear somehow, but no... Then the "MAN SHIFT" light started blinking. I found a way to run the trans. diagnostics on it and all it came back with was a speed sensor. Any suggestions?
Old 08-09-2005, 01:49 AM
My_Probe_Owns_Me_ My_Probe_Owns_Me_ is offline
Originally Posted by scott91probe
hi,
scott
Scott - My Probe is a 1992 and the following is a copy/paste from the 1992 Ford Shop Manual...I hope this can be applicable to your 1991 probe as the 1990-1992 probes are very similar:
SYMPTOM CHART: 4EAT
o Manual Light Flashing
Possible Source(s):
§ 4EAT control module.
§ Sensors.
§ Circuit.
Action(s) to Take:
§ GO to «Switch Monitor Test SM1» .
Unfortunately, the Switch Monitor Test requires a 4EAT tester-adapter. If you get a hold of one, I will type the remaing steps to you--the boxes are not copy/pasting as the text does.
Good Luck.
