Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 03-21-2005, 12:50 PM
jkdon jkdon is offline
Front axel seals
can anyone give me some advice on replacing my front axel seals. I'm not sure were to start. do I need to undo ball joints, tie rods, etc?
thanks
JKdon
Old 03-21-2005, 11:30 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Front axel seals
If you have a Dana 44 front axle, you'll need to get an axle puller and pull out your axles then you'll have access to the insides of the axle so you can replace wheel bearings, seals and all that other good stuff. If you're going to open up your axle for any kind of work, while you're at it, go on and replace your bearings.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 03-22-2005, 01:28 PM
thanks for the help so far. Can I pull the front end housing cover off and unhook the axels there, or do they pull out from the side. I looked at it today and I think I have to pop the ball joints to get this thing out. Do those half shafts have any movement once I get the Wheel bearing off, or does the whole thing come apart? thanks again freaknasty, can't wait to tear into this one. What does the puller look like?
JKdon
Old 03-22-2005, 11:20 PM
ok, from what you're describing, you'll need to remove the front wheel hub nuts to remove the half shafts. I hope you have an impact gun b/c those center nuts are on there REALLY tight. Taking those axle shafts out are like taking out half shafts on front wheel drive cars, ball joints have to be seperated. I believe once you have the shafts out, I'm not 100% certain, but I believe you can get to the seals from the outside of the differential w/o taking off the front cover, I'll check to make sure.
Old 04-08-2005, 12:23 PM
troy1 troy1 is offline
AF -Advisor
oh YEA look at that bad azz 6.1L HEMI. about 420hp?
Old 04-09-2005, 09:10 PM
Re: Re: Front axel seals
yep, optional engine in the upcoming Chrysler 300 SRT-8 and Dodge Charger SRT-8..............
