Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 03-21-2005, 08:43 AM
LCPDuke LCPDuke is offline
Send a message via AIM to LCPDuke Send a message via Yahoo to LCPDuke
99 Grand Cherokee Cooling Fan
The cooling fan on my 99 GC laredo will not kick on. I have tested the fan and it will turn on when connected directly to battery. A fuse was blown number 26 on under dash fuse panel. Changed out but to no avail. I have heard the relay goes bad. I have a haynes manual but can't tell from the drawing where the relay is located. Please help.
Old 03-21-2005, 12:57 PM
tjgindy tjgindy is offline
Send a message via Yahoo to tjgindy
Re: 99 Grand Cherokee Cooling Fan
same problem I had,,, It was the fan relay switch on mine,,, I had to take it to the dealer, but wish I wouldnt have,,, I know it is underneath the headlight or in that area on passenger side,(they didnt put it back together right)
Old 03-21-2005, 01:00 PM
haynes manual, 50025... chapter 3-6 diagram 4.12
Old 03-21-2005, 01:03 PM
mikec041 mikec041 is offline
The switch is mounted behind the passenger side headlight above the vacuum reservoir.
Careful removing the trim screws I snapped one, after several years they get pretty corroded
Old 03-29-2005, 09:29 AM
Where
I looked behind the headlight but couldn't tell where the relay was. Is it a case or what? Under the battery there is what I think to be the vacuum resevoir but it is small and I wonder if the relay is inside that case. Anyother ideas would help.
Old 04-01-2005, 01:10 PM
jkg261 jkg261 is offline
Been there done that. You don't have to take the front end off like they tell you in the Hanyes manual. A dealer parts guy told me this and it took 20 minutes. Take off the right headlight assembly. You have to kinda find the relay by peeping around and then you drill a 2 inch hole through the plastic under the headlight assem, right over the relay. A little finger and wrench work and you can change it
Old 04-08-2005, 03:22 PM
I have taken the headlight off twice now but I wasn't looking under it. I will tonight and hopefully it will work. Thanks.
Old 04-08-2005, 08:08 PM
Trust me its there, the tricky part for me was to make sure that the hole came out right on top of the relay. I ended up being off about a half inch but it was close enough. Afterward I was too neurotic about leaving the hole open and I put Duct tape over it. If you are too far off you can use a dremel tool to cut expand the hole.
Good luck,
jkg261
Old 04-18-2005, 11:27 AM
I fixed it, It was easy to cut the hole and replace the relay. Thanks a bunch for the help.
Old 04-19-2005, 06:31 AM
Re: Re: 99 Grand Cherokee Cooling Fan
Glad to help.
