Go Back   Automotive Forums Car Chat > Ford > Galaxy
Old 03-21-2005, 07:12 AM
speed1975 speed1975 is offline
autolite 2100 carb question......
on my 1965 galaxie I rebuilt a the carb with no problem ut in taking the carb off of the engine I noticed there was nothing connected to the choke???? looks to me kike there should be a line that conects to the bottom of the choke in order for it to heat up as the engine heats up???
what is this and where should it goto???
I am also looking for a vacuum diagram for the car can antone please help...
Thanks
Shannon Fisher
Old 04-02-2005, 03:58 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: autolite 2100 carb question......
This car has a hot air type choke. Right below the choke housing, on the intake manifold, you should see a tiny hole. This is connected to the exhaust cross over passage in the manifold.
As you may know, exhaust gases are used to keep teh intake manifold warm. This provides better fuel vapourization in the intake passages.
If the hot air tube is missing, its easy to make one. Just get a short piece of steel brake line, usually 3/16 inch, and brass fittings to attach it to the carb. Cut and bend the line to fit, and use the brass fittings to screw it to the carb choke housing and the intake manifold.
Old 03-04-2006, 06:38 AM
C. Cleve C. Cleve is offline
Hi, speed1975, If you still have a choke problem, Take the intake manifold off and clean out the crossover exhaust passage under the carb base, It has to be all cloged up with carbon,,,,old thread, old car, old timeers response, See Ya, Clay....
Old 03-04-2006, 10:25 PM
junkyarddawg junkyarddawg is offline
The 65 galaxies had two tubes going to the pass side exhaust manifold to get heat for the choke,there is some vacumn that comes from the choke thermostat housing that sucks the heat from the manifold. One tube bolts to the choke thermostat housing and goes into the manifold and the other comes from the manifold to the top of the carb,the heat air is drawn from the top of the carb down through the manifold and into the choke thermostat. I have a exhaust manifold from a 65 289 that still has the two tubes and could possibly have a manifold from a 352/390 that still might have the tubes. Jeff
Old 11-10-2021, 07:47 PM
10zman10 10zman10 is offline
junkyarddawg is correct two tubes to the exhaust manifold the other posts are wrong they are thinking of another vehicle it's been a long time and I can't remember what vehicles that system is their talking about but it's not ford fe series engine system for sure.
Old 11-11-2021, 06:46 AM
65comet's Avatar
65comet 65comet is offline
The first two were probably referencing a 260. Since it was 16 years ago for the first post, this would only help anyone in the future. My prime guess it was a 390 and agree junkyarddawg had it correct.
Old 11-11-2021, 04:46 PM
being new to this forum I didn't even realize these posts were dated or that they were that old, thank you for pointing that out I guess I should be more observant also I haven't even seen a 221 or 260 in many years and haven't worked on one since the 1960's and if you remember them that well I bow to your knowledge.
