Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 03-21-2005, 03:30 AM
duffduffduff duffduffduff is offline
key removed!! still got power???
After removing my key from the ignition cylinder I can hear a whistling coming through my speakers. This gives me one very dead battery after 12 hours. The ignition cylinder is new. I am unaware if there was anything else I was supposed to replace when I did it. The initial problem which led me to replace the lock was that after I removed the key it was like I was still in ACC (radio, clock, ect.still worked). I dont know if its a short or a sticky relay. Info is scarce in this component. Even with the new cylinder the initial problem is starting to come back. Any help would be really appreciated!!!!
Old 03-21-2005, 03:49 AM
I forgot to mention that it was a 90 celly. When the key is removed the steering wheel pops into the fullt raised position. supposidly telling me the key was removed properly. When the new cylinder went in I stopped having the problem with the radio ect. having power but the speakers still had a whistle
Old 03-21-2005, 08:50 AM
blakscorpion21's Avatar
blakscorpion21 blakscorpion21 is offline
Re: key removed!! still got power???
yea in my 90 i can take the key out and still roll up the windows and sunroof and all that stuff
Old 03-21-2005, 12:06 PM
Genesisfactor Genesisfactor is offline
sorry i couldn't help :-P. My oly suggestion would be make sure the contacts in your ignition are clean and working.
Old 03-23-2005, 03:32 PM
88CiViC_D-15's Avatar
88CiViC_D-15 88CiViC_D-15 is offline
Send a message via AIM to 88CiViC_D-15 Send a message via MSN to 88CiViC_D-15
i say defect in the ignition
Team Lonely Drivers IS LOOKING FOR MORE MEMBERS,CLICK HERE
TLD FOURMS
- 88 civic std w/ sohc zc swap
- 88 integra ls, stock
- lookin for a 4dr. runnin or not
Old 03-24-2005, 11:06 PM
out of curiousity, have you tried simply turning off your radio?
Old 03-26-2005, 11:41 AM
i mean, not to make you seem foolish, but it could mean a whole different problem. If you car is completely off, except your radio, you should rewire the sucker because its probably wired straight into the battery or something.
