Old 03-21-2005, 12:47 AM
whoisdabomb86 whoisdabomb86 is offline
Send a message via AIM to whoisdabomb86
nitrous??
what do u guys think, would a 50 shot be a good idea, the car is wild throught 2nd but in 3rd i could use some help getting up to 5 grand faster, and getting deeper into the 13's..is it worth it...............also my valves tick upon startup ever so slightly, u can hear it with the hood up, but it goes away when the motor gets hot....im running 15-50 synthetic. something to be worried about?
Old 03-21-2005, 01:34 AM
Morley Morley is offline
I doubt you'd see much improvement with a 50hp shot on a V8, maybe 100 or 150.
15W50? Try a 10 or 5W30.
Old 03-21-2005, 09:27 AM
philly rs's Avatar
philly rs philly rs is offline
Send a message via Yahoo to philly rs
Re: nitrous??
yeah i have a 6 and im shooting 100, so i would suggest you do that or more
Your import sounds like my ass after a night of mexican food..
And spraying aint cheating, its brining a gun to a knife fight!!
yeah, its a v6 RS...never mind the f1 badges lol
HYPSI87 u will be missed
Old 03-21-2005, 11:36 PM
100 wet or dry?? and is edelbrock nitrous pretty good or waht?
Old 03-22-2005, 10:31 AM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: nitrous??
15W50?!?! oil prolly isnt goin anywhere fast when its cool on startup, to thick. either go to a thinner oil or get some of the stabilizer or that startup protection shee-ite...
*Better power-to-weight ratio than a C6 corvette*
Old 03-22-2005, 11:53 AM
philly rs's Avatar
Re: nitrous??
wet, i dont mess around with dry systems, everyone has their ideas but i like the way wet systems are set up. also i dont think i know anyone who has edlebrock thats a new brand 4 me so when i go to the shop 2day ill ask some of the guys, ill tell u what i got back info wise.
Old 03-22-2005, 02:01 PM
z28 boy's Avatar
z28 boy z28 boy is offline
Send a message via AIM to z28 boy
Re: nitrous??
Are u gonna spray the hole time or just for third gear? I think dry kits kinda suck. I heard that they are not as effective as wet kits.
R.I.P. Andy, A great guy and an even better friend.
2000 Z28 A4:
Patriot 226 cam, Comp 918's, Comp Ti retainers, HSW 100 shot, Vig 3600 stall, Richmond 3.73's, 2.5in TD's w/ H-pipe & 1-chamber flowmasters, 160* stat, TSP Lid, K&N filter, MSD wires.
Buried Needle Racing!!!
Old 03-22-2005, 03:26 PM
Rod&Custom's Avatar
Rod&Custom Rod&Custom is offline
Send a message via Yahoo to Rod&Custom
Are you sure it is valve tick and not a spun bearing?
Old 03-22-2005, 04:25 PM
100-150 wet N02.
Get that oil out of there, if it is cold out and you start it some parts are not getting lubed right away.
What I'd do is...drain 1 qt of oil out and put 1 qt of auto trans fluid in (yes in the engine not the trans) Run it for a bit (30 minute drive should do it). Drain all of the oil and change the filter. refill with 5W30 oil.
The trans fluid will dissolve sludge and unblock any lifters that may be plugged up and ticking.
Old 03-22-2005, 04:45 PM
WannaLearnMore WannaLearnMore is offline
Re: nitrous??
Originally Posted by Morley
100-150 wet N02.
I'd never heard of that, but that sounds like a good idea.
*Inserting into permament storage area of brain housing group as we speak.*
81 T-Top Z28
350 ci bored .060 over
Edelbrock Torquer Plus Cam, Torquer II Intake
Dart Iron Eagle 202 Heads
Edelbrock 750 Carb (jetted down just a bit to fit)
Custom Built Distributor
MSD 6AL Ignition Control Box
Summit Headers, Mufflers with 3 inch Dual Exhaust
Dual Remote Oil Filter System
Old 03-22-2005, 08:18 PM
philly rs's Avatar
Re: nitrous??
dry dont really suck ass its just for higher shots you need to go wet. i said wet is better because u dont spray through your damn injecters and if i can leave some factory parts out of the abusei will go that rout everytime, but for over i think 150 u should run wet. i know a guy who has 2 stage he goes 400wet and a second shot that is dry and i think its 100.
Old 03-22-2005, 11:32 PM
15-50 from mobil 1 aint all that bad, it stays on the parts, u cant hardly hear the tick and my oil pressure is in the 40's within 4 seconds, then fast at 60psi, its all good tho, my motor is less than 15k on it. im gonna spray just in 3rd gear, so idk dry shot should be good enough, im not going all pro about it, justa lil help
