Old 03-21-2005, 12:42 AM
gjessen gjessen is offline
Question Front passenger side turn signal lights up when hitting the brakes?!?!?
Front passenger side turn signal lights up when hitting the brakes on 97 Chevy 2500 ext LWB. In dash light comes on as well (right turn).The turn signal operates normal.
Already checked the rear light assembly and trailer wiring harness - both seem to be ok.
Problem is not permanent yet, but seems to be happening more and more often.
Any suggestions??
Old 03-21-2005, 09:12 AM
sherman69 sherman69 is offline
Re: Front passenger side turn signal lights up when hitting the brakes?!?!?
Any suggestions??
This sort of problem usually comes back to a bad ground at one of the lamp sockets.
Bob B
Old 03-21-2005, 10:29 AM
Chevy-SS's Avatar
Chevy-SS Chevy-SS is offline
Sherman69 beat me to the punch. Bad ground is almost always answer for this type of problem.
Old 03-21-2005, 08:40 PM
J-Ri's Avatar
J-Ri J-Ri is offline
The filaments in the light could be touching also, happened to me, and someone I know.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-27-2005, 12:27 AM
reher555 reher555 is offline
normaly the ground is the first thing to check. I had a prob with mine once and it was the blinker switch. the hazards blinker brights all work off the same switch. when i depressed the brake my hazards would come on. just a thought!
Old 03-27-2005, 08:42 AM
broughy84's Avatar
broughy84 broughy84 is offline
reher555 is right. these are all through the turn signal switch on the column, with the exception of the hazards. They are on a different flasher. I would check all grounds and change the bulbs. If it still does it, dive into the steering column. Be careful with that air bag in there, pull the fuse and lett it sit for atleast 20 minutes to drain the residual power left in the AIR BAG system before working on it!
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
