Old 03-21-2005, 12:35 AM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Post swapping doors?
hey i think i know the answer but i just wanna ask you guys...will a 88 crx si door fit on my 90 crx si? i wanna get the doors with out the seat belts on door...cause i switched over to 4 point harnesses and looks tacky having the seat belt wholes on doors and yes seat belts on door i took them out...
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 03-21-2005, 09:45 AM
91civicDXdude's Avatar
Re: swapping doors?
yes they will fit
Old 03-21-2005, 04:52 PM
Re: swapping doors?
well i getting told they wouldnt fit?...so you are sure before i go buy a pair that they wil fit?
90 Honda CRX Si
-Red/Black
-B20B/b16
Old 03-21-2005, 09:17 PM
doug294 doug294 is offline
Send a message via AIM to doug294
Re: swapping doors?
How much are you paying for the doors? It might be cheaper to just have your panels recovered.
I get paid to read e-mails when I'm bored....are you bored?
http://hits4pay.com/members/index.cgi?doug684
Old 03-21-2005, 09:57 PM
Re: swapping doors?
thing is i dont want the seat belt mounts on door anymore....its the wholes i am worried about...
90 Honda CRX Si
-Red/Black
-B20B/b16
Old 03-21-2005, 10:13 PM
DirtyD777's Avatar
DirtyD777 DirtyD777 is offline
Send a message via MSN to DirtyD777
I have a si door on my drivers side on my dx..fit's puuurfect
Old 03-22-2005, 02:01 AM
Re: swapping doors?
ya but i wanting to swap a 88 door to my 90 door just to get rid of seat belt mount holes
90 Honda CRX Si
-Red/Black
-B20B/b16
Old 03-22-2005, 07:42 AM
Re: swapping doors?
If you have them recover it they can take the holes "out". I have already checked into it when I switch to my 4 points.
Old 03-23-2005, 08:32 AM
aftershock192 aftershock192 is offline
Re: swapping doors?
i would love to know this to because the 88 hf doors are lighter do to the lack of seat belts on them
90 hf current mods: 94 civic ex engine, darkstar front crossmember, adj fuel pressure regulator, intake much more to come
Old 03-24-2005, 07:47 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: swapping doors?
ok, everyone, stop confusing each other.
you can put 88-89 style doors on a 90-91 car, but they have to be from the same bodystyle. IE: CRX to CRX, hatch to hatch, sedan to sedan. CRX doors do not work on the hatch. the angle at the top is more curved, and the glasses arent even interchangable.
the door panels do swap over between CRX and civic, provided they are from the same grouping (88-89 and 90-91). you can put the 90-91 panels on an 88-89, but you will have the large bulge at the bottom and the slot at the top for the seatbelt system. you could also put the 88-89 panel on the 90-91 door, but only after removing the seatbelt system.
for people with racing harnesses in a 90-91 car, it makes sense to put 88-89 doors on them to lose weight and to make the interior look a lot cleaner. keep in mind that the window glass for the 88-89 is about 2 inches longer than the 90-91, and that the outer pillar trim is a lot skinner on the 88-89.
i think that about clears things up...
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 03-25-2005, 12:52 AM
Re: swapping doors?
thanks man just the answer i was looking for
90 Honda CRX Si
-Red/Black
-B20B/b16
Old 03-25-2005, 01:17 AM
honda_luvr_2000 honda_luvr_2000 is offline
Re: Re: swapping doors?
in light of u'r statement, u r right but not fully detailed. all 88's have seat belts on the b pillar and not the door. only about a quarter of the 89's have the belts on the b pillar. the other 3/4 have them on the doors like the 90 and 91. it might even be as many as all of the 89 from about the mid of Feb 88 thru the rest of the years production. as for everything interchanging like u said... yes it will
as a side note. if u really want it to be clean, also get the door sill molding from an 88 or EARLY 89, that runs along the side of the seat that u only see when the door's open. if not, u'll have the bare spot where the plastic covered bracket was. just making sure nothin is forgotten.
Old 03-25-2005, 09:28 AM
xxxxxxxx xxxxxxxx is offline
Re: swapping doors?
check out my doors man..
Old 03-25-2005, 12:20 PM
regsize regsize is offline
dayum....i like them doors dude..how much did you spend on that stupid thing?? ima get mine done like that...
