Old 03-21-2005, 12:54 AM
ford_50 ford_50 is offline
4th order specs
Does anyone by chance know a place to find specs for a fourth order box. I running a single cerwin vega twelve. Dual voice coil rated at 250w. I'm running an Alpine V12 amp which is 4 x 100. I'm gonna take it down to about 4 ohms. It's going in a trunk of a 1993 corolla.
Old 03-21-2005, 10:39 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: 4th order specs
not sure what you mean, are you going to try to build one? or have one built? or are you trying to figure out the design of your current box? And what do you mean by "I'm gonna take it down to about 4 ohms"?
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 03-21-2005, 09:14 PM
I'm not quite sure why I said "I'm gonna take it down to 4 ohms". My amp spec sheet says it's stable down to 2 ohm. I'm building the box. Maybe the best bet is calling cerwin vega.
Old 03-21-2005, 09:20 PM
sr20de4evr's Avatar
Re: 4th order specs
yes the amp is most likely stable at 2ohm stereo and 4ohm bridged, since you have a 4ch amp and you want to power a single dvc sub the best way to do it would be to bridge each pair of channels to each voice coil seperately, but this will only work if each coil is 4ohm or higher. If your sub is dual 2ohm then the only thing you can do is wire it in series and bridge one pair set of channels to it, leaving the other pair of channels alone.
As for the box specs...to be completely frank, if you don't know exactly all of the planning that's involved in bandpass boxes or how to make a bandpass box properly then you really shouldn't do it. The chance that you'll actually wind up with something decent is slim to none, and the chance that you'll end up with something that sounds like ass and will possibly damage your sub is pretty high. You'd be much better off building a simple ported box instead. Even if you get the bandpass box perfect (which is hard even if you know exactly what you're doing) you'll end up with something that's only marginally better than a simple ported box anyway.
'01 Black Sentra SE
'05 Silver WRX STi
Old 03-21-2005, 10:01 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Re: 4th order specs
2nd that above. I rarely build bandpass boxes anymore unless I have a real poorly designed sub or a poor vehicle like a convert or Wrangler. Bandpass boxes require much skill to build properly. You need to know the perameters of the sub and the general makeup of the vehicle.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
