Old 03-21-2005, 12:08 AM
talontsi26 talontsi26 is offline
high idle
my 93 rt tt is idleing very badly.....but it only idles badly every once in a while...what could be the problem...the rpm sits at about 2.5K...it does this even after the car is already warmed up....also my car dies every once and a while...i start it up, the engine struggles and then the rpm falls and the car dies....what could be the problem???
Old 03-21-2005, 09:29 AM
Igovert500's Avatar
blue + red light magnet
Re: high idle
Could be in need of new plugs, could have vacuum leaks, or it could need new o2 sensors.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 03-21-2005, 11:20 AM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: high idle
Could be dirty throttle body/idle controll valve also, if you havent allready you should do a pressure test on the intake and clean out the throttle body while your at it.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
