Old 03-20-2005, 11:02 PM
j0hn311 j0hn311 is offline
deck problems?
i was in my car the other day and the music wasnt even on loud and i heard a little boom sound and the light on my amp turned red(its normally green). when this happened i thought it was the amp that was blown but about a day later the light turned green again but still nothing worked. I bought a new amp thinking it was the amp that was blown and i hooked the amp up and still nothing works. I noticed however, the subs hit really really really softly, i can feel it and see it a little bit. Next i thought it must have been blown subs, so i bought 2 new subs. still the same thing, they barely hit. All the wiring has been checked and it is all correct so could my problem be like a fuse in my deck or something? how do i check this?
Old 03-21-2005, 08:30 AM
TFFantasy44 TFFantasy44 is offline
Re: deck problems?
What kind of amp is it? Check the RCAs and make sure they are still good, or that you don't have the gain on your amp cranked and other settings all buggered up.
Old 03-22-2005, 12:41 AM
germanyt germanyt is offline
Re: deck problems?
i had a similar problem with a pair of audiobahns. turned out i had a fried voice coil. but if you swaped the subs and it didn't fix the problem then im not sure. try checking the preout connection and make sure it is fitting tightly.
(2) RE SX 15s (www.reaudio.com)
~6.5^3 net @ 35 Hz (polyfilled to increse vol. & lower tuning to 32 Hz)
(2) eD Nine.1s (www.edesignaudio.com)
1 Optima yellow top (www.optimabatteries.com)
1 Optima red top
200 amp alt (www.dbelectrical.com)
eDead V1SE2 250 sq ft
Big 3 (1/0 awg)
Pioneer DEH-P650 (www.pioneerelectronics.com)
Infinity Reference 5 1/4 comps (www.infinitysystems.com
Infinity Kappa 6x9s
MTX Thunder 3404
Power Acoustik TFT/LCD
Pyle DVD/CD/MP3/WAV/WMA player
