Old 03-20-2005, 10:47 PM
jsm98r jsm98r is offline
rear view mirror help
I have a 1998 silverado and I would like to upgrade my rear view mirror, preferably to one with not only compass but temp. Can anyone tell me how this works. I found some silverado mirrors on ebay with temp. and compass, do I just buy one of those and wire it in? Also, is the temperature sensor usually seperate than the mirror itself. Any help would be greatly appreciated.
thanks
justin
also, any help on where I can find a good mirror would also help. thanks
Old 03-20-2005, 11:35 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: rear view mirror help
You may have to run the wiring yourself. Some trucks have the wiring even if they don't have the option the wiring is there for, others don't have it. I believe the temp sensor will not be in the truck, you'll probably have to buy that. The compass and electronics are probably inside the mirror.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
