Old 03-20-2005, 11:45 PM
77chrome 77chrome is offline
Engine Low Idle.
I start my car first thing in the morning and It starts right up and idles fine. But then after the car is warmed up and run for awhile and I shut it off and then start it back up again its idles up and then imidiatly drops to 200,300,400 rpm and somtimes I stall. I rev it and its really rough but then Its fine. Then when I stop at red lights and stuff its fine. I dont get it.
Old 03-21-2005, 04:31 PM
3000gtgrandi 3000gtgrandi is offline
Send a message via AIM to 3000gtgrandi
Re: Engine Low Idle.
is it surging at all?
Old 03-21-2005, 05:05 PM
Re: Re: Engine Low Idle.
yes it surges but not that high. it just kinda putters.
Old 03-21-2005, 05:32 PM
Boosted1 Boosted1 is offline
I have had the identical problem and I never figured it out. It's really weird and it only occassionally does it to me; it's like the engine is struggling and if you rev it up it sounds like it's backfiring really badly.
1993 Mitsubishi 3000GT VR4 (STOCK)
1989 5.0L Ford Mustang (MODIFIED)
http://www.cardomain.com/memberpage/761789
Old 03-21-2005, 06:45 PM
NightRiderGT NightRiderGT is offline
i too have the same problem i though it was because there was too much oil in the engine because my oil temp at idle was way bellow normal temp. when i rev it's fine but then when the needle goes down it all most stalls. maybe its just because my engine is shot to shit i just don't know ?
Old 03-21-2005, 08:31 PM
someone1 help us!
Old 03-21-2005, 09:24 PM
Igovert500's Avatar
blue + red light magnet
Have you helped yourselves? Have you checked your plugs...have your pressure tested for boost/vacuum leaks?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 03-22-2005, 09:12 AM
its def your IAC. you can pick up a use one for like 50 bucks or just rebuilts. the coils go back inside and it make out cars a bitch to drive. i used to hate when mine did that. you can take it out and try to clean it with some intake cleaner. its right on your TB. (bottom left if you are looking at it from the passenger side...) hope this helps.
