Old 03-20-2005, 09:21 PM
cannonball cannonball is offline
alignment problem
My 2002 1500 silverado has a 6in procomp lift.I had it aligned at les schwab and it pulls alittle to the right and the steering wheel is turned a little to the right.They knew it was pulling to the right a little when they gave it to me .Do they know what they are doing? Should i take it back? Is there some tricks to aligning this truck they dont know?
Old 03-21-2005, 12:30 AM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: alignment problem
There are no factory specs for oversize tires (I'm assuming oversize with a 6" lift, I may be mistaken). All they can really do is guess, unless they saved the specs from a sucessful alignment on a similar truck.
To get the steering wheel to center, you can adjust the tie rods.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
