Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 03-20-2005, 09:02 PM
eleveniron eleveniron is offline
Exclamation Tensioner pulley cutting into engine block - CAUTION
1997 Trans Sport - 200,000 kms
I just changed my belt and water pump recently. When I was in there I noticed that the tensioner pulley was cutting into the side of the engine block. When the spring section of the tensioner assembly gets worn, the tensioner arm will sit off-set when the belt tension is on it and the pulley will rub into the block. There is only about a 1/4" clearence there with a new tensioner assembly. My block is OK but the groove is probably at least 1/16" deep and surprisingly very little damage to the plastic pulley. I now realize that there was a slight noise coming from that area of the engine, but it sounded more like a water pump starting to pack it in.
Steve
