Go Back   Automotive Forums Car Chat > Nissan > Cedric | M45 | J30 | Gloria
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 03-20-2005, 08:27 PM
suren suren is offline
95 J30 parking brake adjustment problem
This 1995 Infinity J30 with 93000 miles failed for state inspection-
car will move in drive while parking brake applied. I tighten the
10mm nut located just above the pedal, now parking brake pedal
became more firm, I can't push the car in neutral while emergency
brake is on, but when car is running in drive, it can still
overpower parking brake.
I have not done brake job at the rear wheel, pads or rotor not
changed, owned for last 20000 miles. Need your help what it
could be that parking brake wont hold the car in drive. If I
tighen any more the 10mm nut, it may break the brake cable.
Any suggestions.
Old 03-21-2005, 09:45 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: 95 J30 parking brake adjustment problem
Originally Posted by suren
...I have not done brake job at the rear wheel, pads or rotor not changed, owned for last 20000 miles. Need your help what it
Any suggestions.
The brake wires rust solid because of no exercise, cracked shroud: its like granpa's problem... With automatic P one seldom needs brake. Replace both side wires (and then use it periodically).
...check www.autozone.com for DIY online manual
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 03-21-2005, 12:25 PM
infinman infinman is offline
Nako buddy.WHY DO YOU CONTINUE TO GIVE OUT INFORMATION ABOUT THINGS YOU HAVE NO KNOWLAGE OF!Why don't you just shut your fucking mouth.The j30 has a seperate set of shoes for the park brake alone. Suren : remove your rear tires and you will see a rubber plug{grommet}on your rotor.Remove this plug and it will allow you to adjust the park brake shoes.If you need further info let me know.Don't listen to the ramblings of this mindless idiot who likes to wrap his coils in rubber.
Old 03-21-2005, 12:28 PM
BTW: What does the cartoon of the car supposed to represent?
Old 03-21-2005, 08:10 PM
Thanks infiman. I will remove the wheels and adjust star wheel
thorugh the hole.
Surprise to hear a grommet in the rotor. The other car, maxima
brake was adjusted by the caliper. Will keep you posted. Thanks.
Old 03-24-2005, 02:06 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
infinman: you have been a member here for over a year now, you should know that what you said in the post above is not allowed. This thread is locked and I woudl suggest that you refrain form acting like that again. There is a better way to handle the problem that how you handled it.
Consider this your warning.
-Tim
Closed Thread
