Old 03-20-2005, 08:20 PM
sn01 sn01 is offline
service engine soon light
service engine soon is lighting today,What is the problem.
2002 Intrigue gls 3.5
Thank you very much
Old 03-20-2005, 10:02 PM
Laser17 Laser17 is offline
Send a message via AIM to Laser17
Re: service engine soon light
make sure your gas cap is screwed on all the way... it can also be a sensor, or if your car goes over a certain amount of miles, it might come on automatically
Old 03-21-2005, 06:31 AM
121000km, maybe the emissions pump problem
maybe i will go to the garbage this night
Old 03-22-2005, 11:04 AM
panzer dragoon panzer dragoon is offline
you need an obd2 (obdii) scanner. Some parts places will scan your car computer for free so call around.
An Equus scanner is made well and costs about $120.
--Know the code.
Old 03-22-2005, 05:07 PM
Thank you for you reply ! the code is P0410 air injection. After checking they close the light, during road test the light was off. by the way will i change the timming belt for the 120000km for my 02 Olds Intrigue gls ?Thank you very much
Old 03-22-2005, 05:10 PM
3.5 v6
Old 03-22-2005, 07:20 PM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
There is no timing belt, just chains - 3 of them. One chain drives the 2 intake cams and balance shaft, and the exhaust cams are driven off the intake cams by smaller chains. Hopefully no service is required here. Looks like a major hassle to replace the chains and guides, and special GM tools are needed as well.
Old 03-22-2005, 07:43 PM
kmohr3's Avatar
As far as the code P0410.... basically states improper air flow from the secondary air injection system. Could be restricted hoses, pipes, etc. Maybe even pump or solenoid valve? On my 2002 I was underneath the car putting a fog light in and noticed that the AIR pump pickup was busted off the bottom of the pump. I finally got it reseated and it stays in place, so far. As far as any code I have seen nothing yet. Although I think it needs to be above 41 degrees for the pump to run and it's been cold here.
Old 03-22-2005, 09:57 PM
thank you so much. How much to fix P0410 ?
Old 03-23-2005, 06:32 AM
kmohr3's Avatar
I honestly don't know how much to fix it. You'll probably have to get the dealer involved. How many miles on the car? Maybe it could be covered under emission warranty?
If it happens to me, I'll probably go step-by-step out of my service manual, and/or ask my buddies at the GM dealer (where I used to work) if they'd take a look for me. From reading my manual, it says with the Tech II tester you can manually turn the AIR pump on and off, etc. Maybe the pickup dropped off yours and it sucked up dirt, etc and trashed the pump?
Old 03-23-2005, 05:12 PM
120000km,thank you, It is very nice of you. I have to go to garage of GM.
