Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 03-20-2005, 08:16 PM
Josh_Logic Josh_Logic is offline
1995 Trooper / Oil in spark plugs
This is my first time to these board - I came online trying to find some info on what could be wrong with my car.
1995 Trooper S, 3.2 6 Cylinder, 5 Speed, 155,000k
Engine was running a bit rough. I pulled the spark plug wires off to replace the plugs, and the spark plugs themselves were covered in motor oil (4 out of the 6 were drenched). The shaft that leads down to the plug had oil in it as well. I do not know how long this has been going on - I have had the vehicle about a year and a half and this is the first time I have tried to tune it up.
I wiped out the spark plug shafts as best I could, and replaced the plugs. I did not replace the wires yet due to the cost but will do so as soon as possible. I believe the wires are the original ones, but am not certain.
So, my question is: how on earth did oil get into/onto my plugs? I do not know if that is an indication my engine is completely shot, but I woud like to explore what caused the problem and how I can fix it. Have any of you experienced this before?
Any help/suggestions/insight/comments would be greatly appreciated.
Thanks,
Josh
Old 03-21-2005, 02:13 AM
rodeo02 rodeo02 is offline
No worries. Oil in the spark plug towers is pretty typical on engines of this design. You can pull the valve covers & replace the plug tower seals (O-rings), but some oil in there wont hurt anything.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 03-21-2005, 02:47 AM
Thank you very much! I appreciate your fast reply, and I will sleep much better tonight knowing my engine isn't ruined!
Josh
