Old 03-28-2002, 02:02 AM
92Accord92 92Accord92 is offline
Send a message via AIM to 92Accord92
Help Installing my system!
Sup guys,
I'm installing my new system on Saturday, not sure how to do it, this is my first time. Basically let me tell you what I have, and then if you guys could go in detail on how to wire it.
Pioneer DEH-9300
3 - JL Audio 10w-6's
MB Quarts Mids, Highs, Tweets
MB Quart MUSiComp Crossovers for tweets/coaxials
Punch 200ix DSM - Pushing the Subs
Punch 4020 DSM - Pushing everything else
Rockford Fosgate 1 Farad Power cap
the JL Audio subs are Dual 6 ohm, so if I'm running 3 of them I believe I run 2 ohms to each. Not sure though.
But anyways, if you guys could go in detail on how to wire it, starting from the battery. Like exactly where to wire in the power cap, what wires do I send to and from the amp, how do I hook up the competition crossovers. I think you guys get the idea
If you don't want to type it all, you can IM me at ymerej21
It might be easier that way anyways.....
Thanks in Advance
92Accord92
Old 03-28-2002, 05:18 PM
xivera's Avatar
xivera xivera is offline
Did you get an amp kit(s)?
I/H/E, I.C.E. & other stuff...
Toni/y v0.2|Nice cars thru my lens...
Your first mod = HELMS MANUAL!!!
Old 03-28-2002, 09:17 PM
Yes, I believe I have everything needed to install the system, just not sure how to run the wires.
Thanks
92Accord92
Old 03-28-2002, 10:32 PM
Devedander Devedander is offline
You got 3 subs? That's gonna be a funny lookin box
If you get one of those all in one kits it should come with almost everything you need (I got the biggest fosgate kit I could find, it was only short 1 ring connector and 1 large fuse). As for wiring it up, look at the paper that came with the cap to see how it should be wired, it's a pretty bad drawing but it's not too hard to figure out.
Basically it goes positive on batter to cap, pos on cap to amp(s) (the big amp kit comes with 2 boxes with splitters so your power and ground can be all be split up from one set of sources) ground all amps and cap to something in your car (I used seat belt bolt) wire up amps, charge cap, good to go!
Old 03-28-2002, 10:34 PM
Oh and as for exactly where in line everything goes, 1 large fuse should go less than 18 inches away from the battery (if you get the fosgate kit it is hardwired in) and one fuse between the cap and each amp. My 4 channel amp takes 2 fuses. Add up all the smaller fuses (the ones after the cap) and that's the rating for the big one by the battery. Hope that helped.
Old 04-02-2002, 12:23 AM
dreemkill dreemkill is offline
Send a message via ICQ to dreemkill Send a message via AIM to dreemkill Send a message via Yahoo to dreemkill
i used to have 3 JL 10s in a JL box....looked fine in my car.....and sounded even better
Originally posted by fakirone
.... Nos this, nos that, my 10 second nossy nos will nos your nos.
Originally posted by Prelussion
And then both of you guys w/ you sewing maching powered cars get passed by a moped w/ a 5hp Engine and he goes on to put 5 car lengths on you. Racing an EX vs a DX is like a 10 speed bike vs a golden retriever.
AF Upstate Crew -- Member #1
Current Audio: none. car dead.
