Old 03-20-2005, 05:18 PM
willy_g77 willy_g77 is offline
1991 s-10 blazer back door wont open...
hello, i've tried to get the back door open on the blazer.. only managed to get a screw driver in a crack and get the window part open.. so i need to know how to get the back door panel off while the door is shut. or does any one know how to get it open with out taaking that panel off? i already got the screws at the bottom of the panel.. is there any more somewhere? like in the carpet part??? thanks in advance...
Old 03-20-2005, 06:31 PM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
Re: 1991 s-10 blazer back door wont open...
is the window open? the door latches on the sides, all you need to do is pry on the door latches one at a time .
Old 03-20-2005, 06:45 PM
i unhooked the window with a screw driver, and it came open.. then when i tried opening the door part it opened.. so i closed it all up and tried opening it and it wouldn't open.. so i crawled in the back and opened the window again, and then the door part opened... so when the window is down, nothing will open, but while the window is open the door will..... how can i fix this?
Old 03-20-2005, 07:00 PM
movin2stereo's Avatar
movin2stereo movin2stereo is offline
I'll check into it tomorrow at work.It's been so long since I've been in one of those.I can remember fixing that same problem before.
Stickerchick.com,best decals on the net
Click here
My $12.00 Sunfire
Old 03-21-2005, 07:39 PM
Ther are some screws I believe up around the latch area.Take them out.The panel slides up and pops off.I'm really digging here in my brain.Once thats off you will be able to get a closer look at the problem.Check to make sure all rods are on.
Click here
My $12.00 Sunfire
