The boost gauge on my 1992 VR4 isn't working. Is this a common problem? Does anyone have a suggestion for the best place to start looking for the problem?
Thanks in advance. Steve |
Re: Boost gauge?
Mines not working also, goes nuts when on boost lol, I'm getting an autometer gauge soon so thats what I sugest doing.
1995 3000GT VR-4 Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup. Soon:Topline Engineering ground wires. |
Mine just doesn't move at all. I am thinking something could be unplugged or maybe a bad sending unit. The car recently had new ignition/plugs, timing belt, etc. so it's possible a wire was left unhooked. But I have no idea where the sending unit for this gauge is.
Anyone? Steve |
Re: Boost gauge?
I think it just hooks up with the ECU and uses the readings from the MAS to judge boost, thats why people getting a boost controller are supposed to get a gauge also since the MAS readings aren't a direct measurement of boost and can be inacurate.
Re: Re: Boost gauge?
lol, stock boost gauge = piece of crap
Daily Driver: 2004 Jeep Grand Cherokee Special Edition 1994 Mitsubishi 3000GT SL-TT Automatic - Black 3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods 1994 Mitsubishi 3000GT VR-4 - Black Intake & Boost Controller so far 2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods |
Re: Boost gauge?
when at full boost on stock guage your boosting 14 when your really boosting 9 or 11 depending on generation.
Re: Boost gauge?
How easy is it to install a boost gauge?
1994 3000GT VR4 Pearl Yellow 1994 3000GT Base Pearl White ![]() Check out my Cardomain Website!!!http://www.cardomain.com/memberpage/800196 |
Re: Boost gauge?
depends on how good you are,1 hour or more. a ferw things like the silinoid and electronics you need to hook up.
Re: Boost gauge?
Whats the best second gauge to get? I hear people saying that the air fuel gauges aren't accurate since they're not wideband, what should I get? EGT?
...a boost gauge is relatively simple. The most time consuming/annoying part is routing a vacuum tube and the electrical wiring (for the lighting) down the a-pillar, through the dash, out the firewall and back up to the back of the plenum. It takes patience, a close hanger, and alot of time upside down under the steering wheel.Thourun, EGT is a good choice to go with, but it might depend more on what your future mods/electronics will be...
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
Re: Boost gauge?
I would recomend getting the blitz turbo timer that has a boost guage built in. thats what im getting.
Re: Boost gauge?
Not to argue, but I'd suggest getting a vaccuum based boost gauge that is clearly visable...I know it is alot easier to just glance up at my boost gauge than to glance down at my turbo timer and cycle through different options.
