Old 03-20-2005, 12:46 PM
miah_42 miah_42 is offline
Question pulley install wont fit?
I got a 2003 silverado with the 4.3L. I bought the jet pulleys for my truck and the wont go on. anyone else have this problem?
Old 03-20-2005, 11:57 PM
oh i for got to tell that its the bolt holes arre so close to the edge that they want to go in sideways and cross thread.
Old 03-21-2005, 01:19 AM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: pulley install wont fit?
Did you confirm that you got the right part?
Try installing one of the old pulleys and see if you can get that to go on. Maybe you just have them a bit off center?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-21-2005, 08:23 AM
The old pulley fits nice. i checked and it is the right part #. I tried to put it on for like an hour. Then it took only 5 minuits to install the old one.
Old 03-22-2005, 07:53 PM
I figured out the stock bolts wont work on this install. If anyone else is having trouble with this same thing you need to go to you local bolt store and buy 3 3/8" x 24 x 1 1/4" allen bolts. Then the pulley fits with out any problem. Jet Performance also dont tell you but you need to buy a smaller belt. I went with a 930 belt but might need to go up to a 935.
Old 03-22-2005, 08:59 PM
jeep_cj4x4's Avatar
jeep_cj4x4 jeep_cj4x4 is offline
Send a message via MSN to jeep_cj4x4 Send a message via Yahoo to jeep_cj4x4
Are these underdrive pulleys? I did a search for underdrive pulleys and could only find ones for a chevy cavallear 2.4L.
Are underdrive pulleys effective for trucks or are they more for racing?
2004.5 Silverado 2500HD 4X4, LLY, Banks 6-gun/speed brake/intake, Dual bypass oil filter, 4" exhaust, 265/75R16 Bridgestone Dueler A/T Revo2, AirLift airbags, AMSOIL in everything!
84k miles/30NOV11
Yeasu 857D/ATAS-120A - "When all else fails..."
