Go Back   Automotive Forums Car Chat > Ford > Contour
Old 03-20-2005, 11:32 AM
JimR's Avatar
JimR JimR is offline
Check engine light
my code is PO171. i have cleaned my MAF as said on http://contour.org/mods/mods.php?s=howto&displayid=36 ,changed both O2's, change the air filter. what else could be my prob? 96 2.0L
note this is the 4th time in 6 mounths it has come on with the same code
Old 03-20-2005, 02:23 PM
Jason43's Avatar
Jason43 Jason43 is offline
Re: Check engine light
I searched that code on contour.org relating to a zetec. In addition to the dirty MAF and O2 sensors, it looks like it could be caused by a vacuum leak.
Just go to contour.org
1999 Ford Contour SVT
Old 03-25-2005, 09:53 AM
JimR's Avatar
what kind of leak, internal? because i dont hear a sucking noise.
Old 03-27-2005, 09:43 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
First clean the MAF censor.
or
http://www.contour.org/ubbthreads/sh...rue#Post755510
my old post, have fun removing it as it's a common problem with these cars. Mines been on forever and I've changed everything but still no luck.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 03-28-2005, 12:06 PM
JimR's Avatar
i did cleaned the MAF.
Old 03-28-2005, 01:15 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
It could be a very small vacuum leak, perhaps around the pcv system or somewhere after the MAF. somehow, i bet unmetered air is getting into the engine so its not being picked up by the MAF and its running lean.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 04-28-2005, 07:37 PM
riverat440 riverat440 is offline
Re: Re: Check engine light
Any luck with the 171 code. I just ran across one with the same problem and have checked all over the intake with no luck. With no other codes showing up and have run on the diagnostics computer and all related sensors are operating within their allowable ranges this is turning into a real pain. Hopefully someone has an answer if this is a common problem. I guess it just another one of those ford things huh?
