Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 03-20-2005, 11:31 AM
JBS JBS is offline
My Aries hates me!
The other day I had a problem in the morning starting my little car. after I did get it going I thought there was water in the tank because it was running fine then yesterday as I was driving up one of our mountain passes The car started to steam heavily. I have a cracked rad and I knew about it for quite some time so I thought it was just more steam but this time it was alot more than usual. As I continued it started to loose power and stalled out I could not get it to start at all. When I looked under the hood the rad cap had blow off and there was fluid every where. Still not being able to start it I let it coast down to the nearest town and when it eventually came to a stop it started again but ran like shit and I had to rev the piss out of it again to keep it going. So I crawled my way back to my house at 90 km/h and turned it off. Now this morning I went to sart it and nothing it does not even try to fire and I got a code 27 meaning 27 Logic Module Fuel Circuit at least that is what I am told any Ideas guys.
Old 03-20-2005, 10:27 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: My Aries hates me!
I hope you didn't run it for too long to were you warped your cylinder head! Do a compression test and see what goes from there
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 04-03-2005, 11:55 AM
Ryan066 Ryan066 is offline
this could be a lot of things but first I would check your rad... sounds to me like something is clogged... excessive pressure build up would cause the cap to blow off.. (over 18 PSI).
Old 04-03-2005, 11:56 AM
code 27:
27 Injector circuit isn't switching when it's told to (TBI)
OR (MPI) injector circuit #1 not switching right
OR (turbo) injector circuit #2 not switching right
OR (all 1990-) injector output driver not responding
- check computer, connections
