Old 03-20-2005, 11:25 AM
cupa cupa is offline
Unhappy 95 blazer wont start
hi to all,its actually my doughters vehicle.she has a 95 blazer with the vortex v6 engine.the engine stop running about a week ago,checked for a spark had one,tried some starting fluid and almost started.the vehicle has 140,000 miles,so i changed the fuel pump and filter,checked the pressure and its within specs. still wont crank over.for some reason the its not getting fuel.i have a scan tool but will only read 96 and up.
thanks in advance for any help.
Old 03-20-2005, 12:27 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: 95 blazer wont start
injectors could be clogged, when you turn the key does the pump prime?
Old 03-20-2005, 05:12 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
What fuel pressure were you getting?
We need the actual numbers.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-21-2005, 05:58 AM
Re: Re: 95 blazer wont start
i believe it was 60 psi,and yes the pump primes for approx 2sec.
i was looking towards the fuel pressure regulator. i read something similar in another thread.
Old 03-21-2005, 07:05 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Pull the upper plenum and check for washing, but you have enough pressure. I would meter the wires (make sure that all wires are getting the same resistance). Check the ignition module and coil. Just because you saw spark, doesn't mean you have a strong enough one. Check cap and rotor as well. Though the pump priming for only 2 seconds does concern me.
When you did your pressure test, how long did it hold pressure before it started dropping?
Old 03-21-2005, 07:36 AM
let me refrase,the pump primes for several seconds,when i put some starting spray on the intake manifold it acts like it wants to start.other than that the engine turns over but doesnt even act like its going to start.imho it seems like its not getting any fuel.
ive had clogged injectors on other vehicles,when they were clogged the engine acted like it wanted to start.before this happened the vehicle did the same thing twice but started. i need to get a diagram for the fuel sysytem.
Old 03-21-2005, 07:39 AM
rlith's Avatar
You have a single injector to 6 poppets batch fired. Pull the upper plenum and check for washing. If a poppet is stuck you can try clearing it with an airhose (dealer way) or simply replace the unit. But again your fuel pressure is fine and even with 5 poppets open you should be able to start because it's a batch fired system. I still would be looking towards spark. Like i said, your spark may not be strong enough
Old 03-21-2005, 08:01 AM
l im not familiar with(single injector to 6 poppets batch fired)
also you mention washing,sorry but am not familiar with those terms.can you be more specific.
thanks for all your help
Old 03-21-2005, 08:07 AM
rlith's Avatar
You have a CPI unit. It is a single injector housing that has 6 lines coming out of it. Everytime the injector is pulsed, fuel flows from all 6 lines. This is called batch firing. 96+ use a similar setup but the hoses are fired in sequence (165432).
Your injector unit is located inside the upper plenum. Washing means that one side of the plenum is cleaner than the other because it has been washed with gasoline. This indicates a leaking CPI unit or a leaking NUT KIT (The inbound outbout fuel lines on the drivers side of the intake that connect to the CPI). Your poppets (the end of the injector hoses) are a simple check valve system. They open up at about 56 PSI. So when you said 60 psi, I determined you have enough pressure.
Also, how fast does the pressure drop when the fuel pump stops priming? (ie. when you turn the key off)
I should also note that if your fuel pump is priming and the cpi unit is ok, and you can confirm proper spark power (did you meter your wires and check for arcing at the coil) and your ignition module (attached to the coil) and cap and rotor is ok. It is most likely your fuel pulsator (located inside the tank)
Old 03-21-2005, 11:20 AM
i dont remember seen a pulse locator when i dropped the tank?
thanks for all the help
Old 03-21-2005, 02:19 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: 95 blazer wont start
If you want a quick check, remove the top vortec name plate on to of the engine, then remove the round black valve underneath it and take a flashlight and look down into the hole and look for the strong smell of gas and golden washed spots inside.
The washed spots are from the gas washing the black grime that is normally supposed to be in there.
Old 03-21-2005, 02:21 PM
rlith's Avatar
It's called a PULSATOR UNIT, not LOCATOR... It's part of the sending unit. It can be replaced. About 40 bux at the dealer.
Old 03-21-2005, 02:34 PM
^well he didnt LOCATE it
Old 03-21-2005, 03:18 PM
Smile Re: Re: Re: Re: 95 blazer wont start
i removed that round black valve looked inside,it has black grime,but there was no smell of gas from the inside.
tomorrow im borrowing a fuel pressure gauge from one of my friends who owns a shop to make sure that what im reading is correct.
Old 03-21-2005, 05:33 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: Re: Re: 95 blazer wont start
Did you look down into the hole in the plenum and look for washed spots?
