Old 03-20-2005, 12:09 AM
biglogonafrogbig biglogonafrogbig is offline
Spray Paint
Has anyone here had any experiences with the spray paint that is made for touching up paint on trucks thanks
Old 03-20-2005, 05:26 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Spray Paint
I used some on an Astro I used to have. I got the correct paint, but the stuff in the can was darker due to the paint on the van fading over time. It didn't peel off in the time I had it, but it was only about a year after the touchup.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-20-2005, 07:56 PM
Have you ever heard of anyone painting the entire vehicle with the spray paint
Old 03-20-2005, 08:14 PM
Pat_OD's Avatar
Pat_OD Pat_OD is offline
yea this guy i know spray painted his 85 F150 bright orange ugliest thing i've ever seen. 1 of my uncles used a teal paint from a paint can and used a roller to paint his old station wagon
Old 03-20-2005, 08:59 PM
How do you think it would turn out painting it like a jet black from a spray can or something close to that color
Old 03-20-2005, 10:14 PM
Pat_OD's Avatar
like shit........dont do it
Old 03-21-2005, 12:08 AM
J-Ri's Avatar
Re: Spray Paint
What year truck are we talking about? I don't like the old ones ('86 and older) all black, but I think the new ones look ok. If you end up painting it, get it really clean first. Sand it down with 1500 grit paper, then apply the paint. Put on as thin of a coat as possible. If you have to put on 10 coats, that's better than having 3 layers run. Also, sand it by hand or the paint will look wavy. Good luck if you decide to do it!
Old 03-21-2005, 12:10 AM
J-Ri's Avatar
Re: Spray Paint
Also, if you can, practice on a beater car. I can guarantee you'll screw up in some way the first time you paint a vehicle.
Old 03-21-2005, 12:30 AM
Wheeler88's Avatar
Wheeler88 Wheeler88 is offline
Re: Spray Paint
Either your being silly or every nut on your truck is rounded.
88' Chevy K1500 Silverado
350 V8 5.7
Original Owner
77,000 miles
2nd tranny
Peeling Paint - Defective Factory Paint
235/85/16 BFG MT
Old 03-21-2005, 09:44 PM
sub006 sub006 is offline
Re: Spray Paint
Yes, I painted my 90 Suburban from the seam near the top of the side windows to the bottom of the body. I used the large size spray cans of touch-up paint. I pounded and pulled dents, bondoed, primed, and then painted one panel at a time.
Masking is CRITICAL and it takes too long to mask an entire truck working alone and outside. Wind might come up, etc. My truck is metallic gray and it took about eight cans ($40) to do it all. The paint wan't glossy and I didn't want to try polishing it (cans lay it on too thin), but I had a nice even color that blended with the weathered paint on the roof.
Didn't paint the roof because you need a LONG bench to walk back and forth spraying full length.
On a pickup maybe you could work standing in the bed.
My truck was presentable for a couple of years before I got a pro paint job.
Old 03-21-2005, 10:59 PM
Did you sand it down before painting it, and did you take the panels off or just paint them on the truck thanks
Old 03-21-2005, 11:08 PM
J-Ri's Avatar
Re: Spray Paint
Almost forgot... I painted the hood, roof and trunk on my buddys beretta. I sanded it, although not down to the metal (just to give the new paint something to grip on to), it turned out great. It lasted for at least 2 years, he sold it, but it lasted 2 winters and a summer in Iowa. We masked off the windows, trim, etc., and didn't have any problem. Just used that blue painters tape and newspaper. Make sure you tape the seams in the newspaper, or paint dust will get through if there's not much overlap.
Old 03-22-2005, 08:01 AM
Re: Spray Paint
I painted the panels ON the truck. As I recall I sanded the old surface with maybe 320 or 400 grit, shot spray can primer, then lightly sanded the primer with 600 just before shooting the color coats.
Old 03-22-2005, 10:27 AM
Heres the exact truck you all are saying that you did do it with spray paint that you can buy at the local automotive shop right thanks for the help
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Old 03-26-2005, 07:28 AM
clampjockey clampjockey is offline
Re: Spray Paint
is there a forum here to help "do it yourselfers" learn to do autobody work? would love some feedback on what materials to use and what kind of paint to use etc. my very first body/paint job was nearly a disaster. seemed like the spot putty i used reacted with the paint and kinda curdled the paint/body fill. i'm thinking of doing anothr body/paint job and wouldn't want that to happen again.
