Old 03-19-2005, 11:31 PM
igkyoa igkyoa is offline
accord 2000 governor
does any one know what the governor on a 2000 accord is?
Old 03-20-2005, 06:21 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: accord 2000 governor
Not sure what you are asking, but if you are talking about the max governed speed, it is a function of the engine control computer, not a physical part. It can only be changed by reprogramming (i.e. performance chip)
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 03-20-2005, 06:37 PM
i guess i didnt word that very well, but what i was trying to ask was if anyone knew what the max speed you could go in a 2000 accord was before the govenor kicked in
Old 03-21-2005, 03:02 PM
blacknight's Avatar
blacknight blacknight is offline
my car at the top of 4th. would have gone faster but I ran out of road
here's a V6 Accord
what's that red button on your steering wheel.......OOOHHH MMMYYY GODDDD :22yikes:
Old 04-22-2005, 02:51 PM
jasolini jasolini is offline
how did u get ur accord to go its full potential? my accord cuts off at about 110-120, can anyone tell me what i need to do to get its full potential?
some say get a chip , some say take out a chip and thats all i need to do , some say keep chip and add another one, which is it?
jason
i have an 01 accord 2 dr, v6 vtec 3.0 and it shuts off at about 110 -120 , i can tell very clearly, some say i need a chip some say take out a chip , which is it????
Old 04-22-2005, 03:04 PM
blacknight's Avatar
Personally, I haven't done any ECU upgrade (modification) to my Accord and I have a 4cyl. I know a few guys who have exceeded 120 in a V6.
Check out www.v6performance.net
Old 04-22-2005, 03:44 PM
StealthSonic StealthSonic is offline
going down hill??
http://importfan_accord.homestead.com/files/New_Page_Accord.jpg
Old 04-23-2005, 07:38 PM
lamehonda's Avatar
lamehonda lamehonda is offline
I had my speedo at about 131 in New Mexico last year. Mine is a 99 4cyl 4dr. It really struggles once you hit 5th gear and then starts to recover at like 124. My governor never kicked in, so I figure that my speedo must be a little off.
Old 04-25-2005, 12:10 AM
Hatrick101's Avatar
Hatrick101 Hatrick101 is offline
Mine stops at 132 @ 4500 in my auto 4cyl coupe Reached it a good 10 times.
Old 04-25-2005, 10:09 AM
blacknight's Avatar
Re: Re: accord 2000 governor
Yeah, I topped out at 125 in 4th gear. The problem is because the 4 bangers are really drag limited. There's not enough power to keep the cars momentum going through the air at that speed. That's why it's a little difficult in 5th gear. Also, since 5th is really the overdrive gear, the gear ratio is less than 1 which means the drive wheels are moving faster than the engines RPM's
Old 04-25-2005, 06:46 PM
AccordCodger AccordCodger is offline
Well, not really. It means the transmission output is moving faster than the input. What the final drive ratio does is something else altogether.
FYI, I don't know about earlier models, but the current Accord's 5th AND 4th are overdrive ratios (probably because the latest motor is a little larger).
But I agree about drag. Everyone seems to be hung up on the speed governor, but my guess is that drag's gonna get you first on anything except a pretty punched-up Accord configuration.
Old 04-25-2005, 09:15 PM
lamehonda's Avatar
The stock version feels like it has pretty much run out of steam at 130. I wonder if any turboed 4cyl guys have tried for top speed?
Old 04-26-2005, 10:49 AM
blacknight's Avatar
I just checked the gear ratios and you're right, on the 7th gen (03+) 4cyl Accords both 4th and 5th gear are can be used as overdrive cause the ratio is lower than 1
Transmission Print This Page
5-speed manual w/OD
Specifications
Transmission gear ratio (1st) 3.27
Transmission gear ratio (2nd) 1.77
Transmission gear ratio (3rd) 1.15
Transmission gear ratio (4th) .87
Transmission gear ratio (5th) .66
Transmission gear ratio (reverse) 3.58
With the 6th gen Accord (98-02) it's basically the same, just 4th gear isn't as low
5-speed manual w/OD
Specifications
Transmission gear ratio (1st) 3.28
Transmission gear ratio (2nd) 1.80
Transmission gear ratio (3rd) 1.19
Transmission gear ratio (4th) 0.90
Transmission gear ratio (5th) 0.68
And here's what they say about overdrive, so I guess we're both right
Overdrive
An overdrive transmission has a final gear ratio that is less than 1:1. This means the drive shaft turns faster than the engine crankshaft, permitting the vehicle to maintain a constant speed at lower RPM. At highway speeds an engine runs quieter and consumes less fuel when overdrive is engaged.
Primary Benefit:
Overdrive improves highway fuel economy. In an era of government-mandated fuel economy, the advantage of overdrive is so overwhelming that almost all manual and automatic transmissions incorporate one or more overdrive gears.
Old 04-26-2005, 12:57 PM
I only take issue with the term "final gear ratio." It doesn't make it clear, but if that is SUPPOSED to include the final DRIVE ratio, IMHO it's wrong.
If the "drive shaft" referred to is that in a RWD vehicle, with a separate diff, then it's sort-of OK. But it's a different story with a transaxle (like the Accord's).
