Old 03-19-2005, 07:00 PM
pf8kcab217 pf8kcab217 is offline
Thumbs down Rear Brakes Locked 1996 Windstar
Hi
I have a 1996 Ford Windstar. It has been parked for 3 mos. Today I started it and tried to back it out of the drive. I found the rear brakes totally locked up, the car will not move. Any suggestions as to possible cause?? Any similar stories?? Suggestions??
Thanks.
PGF
Old 03-19-2005, 07:47 PM
wiswind wiswind is offline
Re: Rear Brakes Locked 1996 Windstar
Is the parking brake set?....
If it was set......it may not have released at both wheels.
I have not had that problem....but perhaps a look under the car....and follow the parking brake cables back.......
Old 03-21-2005, 08:19 PM
cougarman cougarman is offline
I have seen this many times with many models. Brake shoes could be rusted to the drums. The rust acts like " glue" . Remove rear wheels,
hit the drums with a hammer, (which unfortunatly may damage drums if hit to hard in the wrong places ) to try to break it free. Also as stated in the other reply your cables may be siezed.
Old 03-21-2005, 10:15 PM
BCMedic BCMedic is offline
Cougarman is correct, the only thing I might add is to make sure the parking brake is released as wiswind stated, jack up the rear so the back wheels are off the ground and try rotating each one back and forth by hand to break them free.
If you can't budge them, try popping the adjuster plug out and ratchet down the pawl adjuster.
Old 05-29-2005, 08:19 PM
mb8353 mb8353 is offline
My wife's Junkstar did the same thing last Christmas. I took the cap off of the master cylinder which relieved enough pressure in the lines to get it back to the house. Then I replaced everything! Approximately, $300.00 as opposed to the $650.00 Meineke quoted. Hope that helps!
