Old 03-19-2005, 04:52 PM
larrylwill larrylwill is offline
inside mirror removal
Can someone tell me how to remove the inside mirror. It has a barrel connecting it to the plate. I want to change it with an auto darking mirror with compass.
Old 03-19-2005, 09:43 PM
NakedDancer NakedDancer is offline
If I'm not mistaken it's just a allen wrench, torx bit, or a plan old screw that usually holds it to the plate. Look for the screw thats holding it on,
Now remember, I like most people on this site are not master mechanics. These are places I would start on my own car. My advice cost you nothing but, maybe some time. If it's right or wrong please report back so someone else (maybe even me) will know where to look if I/they have the same problem. Good luck
Old 03-20-2005, 12:58 AM
Re: inside mirror removal
If it was only that easy. I'd attach a picture if there was a way. Its not like any other mirrow bracket I've ever seen. There is no screw you cant see the base only the mount which looks like 1/2 a barrel.
Old 03-20-2005, 01:01 AM
Heres a picture of it.
Old 03-20-2005, 09:54 PM
Ok well I found a site that can help you. http://www.tintdude.com/forum/index.php?showtopic=9301 whatch this post for a pic (the guy says monday) or just ask how to remove it there and post your pic.
Old 03-20-2005, 11:07 PM
Re: Re: inside mirror removal
Thanks, I joined and posted the picture.
Old 03-21-2005, 08:22 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
There is a small slot that you can insert a small screwdriver and depress a locking tab inside the base. Then it pulls off. The little slot is to the left in the picture. On the windshield it is on the bottom.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 03-21-2005, 12:28 PM
That makes the most sense. Here is what I got from the other forum.
"just pull it down and i will pop off..."
Old 03-21-2005, 12:57 PM
Willyum Willyum is offline
On my '02 after you clear away the plastic, push the mirror up, is on an A shaped mount on the windshield. No screws or bolts.
Old 03-21-2005, 01:06 PM
There is NO plastic, its all metal.
Old 03-21-2005, 01:12 PM
Re: Re: Re: inside mirror removal
Well seems like everybody was wrong. I just got it off. I was trying to find a tab to push, in the bottom and started wiggling it, but couldn't feel a tab. However I saw it moving.
Here is the solution.
Just wiggle it side to side and pull it up at the same time and it comes off. No screw, no tab. just a slide on.
