Old 03-19-2005, 04:21 PM
crashflyer crashflyer is offline
97 C-1500 starting problem
Hello,
got a 97 C-1500 Silverado 350 auto 170,000mi with a intermitent starting problem. Engine rolls over fine I have spark and fuel coming out of the test connection when I hook a hose to it. Also I can hear the fuel pump kick on when the key is turned on. About a month ago the truck would not start and it was about 15 degrees out so just figured I had water in the fuel since I had filled up the previous day pushed it in the garage and heated the garage up after a few hours no problem truck started fine. Today the same problem just coughs on a couple of cylinders and does not start. Today it is about 38 degrees though so water in the fuel should not be a problem. I was searching the threads and most of them indicate a pass-key or vats problem. I do not believe I have a security system on this truck it has remote door openers but no remote start. I did not put a pressure gage on the fuel test connection just hooked a hose up and let it run into a jug seems like plenty of fuel comeing out though.
Any help would be appreciated
Thanks
Old 03-20-2005, 01:18 PM
Re: 97 C-1500 starting problem
Fixed the problem... New cap rotor and wires, works fine. 170,000 on the original stuff not bad for a Chevy.
Old 03-21-2005, 10:37 AM
Chevy-SS's Avatar
Chevy-SS Chevy-SS is offline
Glad you fixed your problem.
