Go Back   Automotive Forums Car Chat > Honda > Integra
Old 03-19-2005, 04:57 PM
AJ96Integra AJ96Integra is offline
Send a message via AIM to AJ96Integra
Springs
Hey again. Along with my short throw i just bought, i just bought new Eibach springs. I basically kno how to install springs, but i just want to make sure if there is any big things i should look out for when installing my springs
96 Integra LS
Old 03-19-2005, 05:33 PM
nu-b94teg nu-b94teg is offline
Just make sure you use a spring compressor. If not you can get hurt. Are you using stock shocks?
Old 03-19-2005, 06:15 PM
im just getten the eibach pro kit springs
96 Integra LS
Old 03-20-2005, 11:17 AM
Si Integra Si Integra is offline
Send a message via AIM to Si Integra
Re: Springs
No offence intended, but I have changed probably many spring setups on various hondas and never once used a spring compressor. If you jack the car up all the way most of the tension is removed from the springs. I use an impact to remove the top nut from the struts and have never once had a problem.
The biggest problem is the lower control arm and trailing arm bushings and the bolts seizing up and breaking off in the bushings. (This is more of a problem for the DA integra, rather than the DC's.)
**PB Blaster is your best friend**
(you can find this at any parts store, ie; autozone)
Good choice on the springs, those are the springs I use on my turbo car and love them.
Old 03-20-2005, 01:12 PM
K2sInteg98 K2sInteg98 is offline
i would recommend getting new shocks soon. Your stock ones will last for a while then your ride is going to be reallly bad.
Old 03-20-2005, 03:04 PM
any recommendation on a specific kind?
96 Integra LS
Old 03-20-2005, 05:42 PM
Re: Springs
I think the KYB AGX are a nice addition to the eibach springs. Also you may consider koni yellows or tokico illuminas.
Based off my experiance with all three, I recomend the agx struts. Dollar for dollar a great set and handleing/stopping is drasticly improved over stock.
Old 03-20-2005, 10:07 PM
yeah the KYB, Koni, and Tokico are gonna be your top three choices. It will improve your handling and ride a lot better then your stock shocks. You wont regret getting new shocks.
Old 03-21-2005, 04:24 PM
Have you ever heard of the KYB GR-2 Shocks?
96 Integra LS
Old 03-21-2005, 10:25 PM
I kno you guys were talken about the AGX struts from KYB but these GR-2 are cheaper. Do you think they will work with these springs???
96 Integra LS
Old 03-22-2005, 05:15 PM
Does anyone Know if KYB GR-2 Struts and shocks will go good with Eibach Springs????????
96 Integra LS
Old 03-22-2005, 09:06 PM
http://cgi.ebay.com/ebaymotors/ws/eB...962493284&rd=1
These are the KYB GR-2s
96 Integra LS
