Go Back   Automotive Forums Car Chat > Honda > Integra
Old 03-19-2005, 03:29 PM
s13dr1fter s13dr1fter is offline
Send a message via AIM to s13dr1fter Send a message via MSN to s13dr1fter
B-series turbo
What do u guys think is better for turbo in the B-series motors?
Old 03-19-2005, 04:36 PM
nu-b94teg nu-b94teg is offline
I would say B18B (LS) cause of the lower compression, you can boost more on stock internals. Its a real good idea to build your engine up before boosting.
Old 03-19-2005, 04:40 PM
CBURKE's Avatar
CBURKE CBURKE is offline
Re: B-series turbo
What is the boost on stock like 8psi's?
98 MITSU GST, 1990 TURBO MOTOR
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
Old 03-19-2005, 07:32 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: B-series turbo
i've heard with good tuning and proper fuel management the internals can safely hold 12 psi for short amounts of time (drag racing and such) as long as it's a strong and well maintained engine
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 03-20-2005, 12:31 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: B-series turbo
any stock b series motor will be good for boost with the exception of the b20.
search.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 03-20-2005, 10:03 AM
Si Integra Si Integra is offline
Send a message via AIM to Si Integra
Re: B-series turbo
I disagree!
I have quite a bit of experiance with boosting hondas and I would not take an LS or vtec motor over 6-7psi on stock internals. Don't get me wrong, I have seen people boost 20psi on a stock b18c1, but it wont last.
Which ever way you choose to do it, tuning is key! and building the block to handle the extra power is a must.
I like the transmission the ls's come with for boost purposes; however, the ls makes slightly less power than say a type r or gsr under the exact same boost conditions.
Tuning and boosting for a novice is idealy on an ls b18b motor. The only reason for the b vs. the a is the better cams and intake manifold/throttle body design.
IMHO, save for a good engine management first. I recomend the aem ems, it is dollar for dollar the best tuning tool you will find. It definitely beats uberdata and hondata.
If you are looking for a cheap setup, go with an uberdata setup.
Another thing to consider is keeping your engine cool under the extra strain. Perhaps investing in a oil cooler and better radiator should be considered.
