Old 03-19-2005, 02:23 PM
mike5721947 mike5721947 is offline
Send a message via AIM to mike5721947 Send a message via MSN to mike5721947
plactic model paint on wood?
well i am wonding if i primer a co2 car that is made of wood if i could use plactic model paint on it?
EX-Owner of a grey 1986 Oldsmobile Cutlass Ciera Brougham
its gone towards the kidney foundation car autions.
EX-Owner of a blue 1991 pontiac firefly turbo
Now own a 1990 suzuki sidekick 3" lift, 235 A/T's winch bumper, and way to many km's.
also a beater hyundai pony from way back in 1985
Old 03-19-2005, 03:23 PM
freakray freakray is offline
AF Modelrater
Re: plactic model paint on wood?
Why not?
AF User Guidelines
Old 03-19-2005, 04:17 PM
tardster tardster is offline
It should but the only problem you might have is the paint soaking into the wood so you may have to prime it several times before you paint it if you want the shininess that you see on most models...
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Im building a CO2 car as well. Im just going to use Tamiya.
-Mike
Old 03-19-2005, 04:23 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Getting a good, shiney finish on a pine car is going to require ALOT of woodworking before hand, and it would be much more difficult than doing it on plastic. pine is just way, WAY too grainy to give a good even shiney painted finish. But, hobby paint will work just fine. And, you don't need primer for adhesion, like you would on plastic. If you want to use something under the hobby paint, forget the primer and use a wood sealent.
PHOTOBUCKET SUCKS
