Old 03-19-2005, 07:55 AM
Amazon's Avatar
Amazon Amazon is offline
Question How to clean my needle files?
I think my subject says it all,but i need advice. Those finely cut files are too small to be cleaned out manually. So there must be a way chemicals can solve this problem? My files are clogged up with the usual debris; styrenedust,epoxifiller e.t.c. the usuall that sticks to it during filing.
So, how do you clean yor files? Thinner?( doesn`t remove filler or styrene) Some household cleaner, like Ajax? Tell me, it`s a pity to throwèm away although they`re cheap..
Newsflash: Diecast sales fund terror activities.
Old 03-19-2005, 09:10 AM
hawkone hawkone is offline
Send a message via AIM to hawkone
Re: How to clean my needle files?
hi amazon what i do is after every use and during use i use a suede brush its hard bristles at edges then in the middle brass bristles does for me.
mind you i did use some revell color mix thinner the other day it helped hope this helps
Old 03-19-2005, 09:20 AM
freakray freakray is offline
AF Modelrater
I've heard of using lacquer thinner to clean them, but I use a fine metal brush wheel in my dremel.
AF User Guidelines
Old 03-19-2005, 09:27 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
Carburetor Cleaner. Let them soak for a couple days.
Make sure you romove the handles if they have them. Hopefully they don't have permanent plastic handles or they will melt off.
After rinsing in water with a little detergent, a soft brass wire brush will clean them up nicely... - Mark
Old 03-19-2005, 09:58 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
When I'm filing stuff I wipe them on my jeans every few minutes to keep the build up down. But after awhile, I'll have to clean them with something. Usually the tedious way with an X-Acto.
-Mike
Old 03-19-2005, 11:00 AM
mikemechanic's Avatar
mikemechanic mikemechanic is offline
I just drop them in a container of lacquer thinner and brush them out with an old toothbrush.
Old 03-19-2005, 02:36 PM
spidereddie's Avatar
spidereddie spidereddie is offline
Send a message via AIM to spidereddie Send a message via Yahoo to spidereddie
what exactly are needle files and where can I get some (if they are what I think they are)?
Ed-
Old 03-20-2005, 03:15 AM
Fooesboy's Avatar
Fooesboy Fooesboy is offline
If they are clogged with white metal you can use a soldering iron to melt out the metal.
Old 03-20-2005, 04:04 PM
Sticky Fingers's Avatar
Sticky Fingers Sticky Fingers is offline
Re: Re: How to clean my needle files?
Then, what do you use to get the stuff out of your jeans!
Old 03-20-2005, 04:59 PM
mike@af's Avatar
Re: Re: Re: How to clean my needle files?
You havent seen my jeans then. I guess I should post a pic . They have oil, grease, burns from welding, and all sorts of crap all over them. They also have some equations and measurements for the 1/6 written on them.
-Mike
