Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-18-2005, 10:17 PM
atomicpulse's Avatar
atomicpulse atomicpulse is offline
weird idle
The last I'd say 6 days my idle has been acting wierd.. when I first start driving my car the idle will be around 750 to 800 rpm, but then jumps up to 900 and 1000 and stays there, and will not come back down till I let my car sit with the engine off for a while. Any idea what this could be?
Old 03-18-2005, 10:40 PM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
Re: weird idle
evac? vacum leak?
Old 03-18-2005, 11:30 PM
Re: weird idle
and i forgot to mention that the rpms like to jump from 800 to 1000 up and down constance.. but as i said shut it off and let it sit for say 15-20 minutes and the idles are normal again :S
Old 03-19-2005, 12:53 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: weird idle
it might have a slight misfire, but i would say that you probably have a vaccuum leak. Check the PCV valve and all the vaccuum connections that you can find, otherwise bring it into a shop and have them run a vaccuum test or a diagnostics test.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 03-19-2005, 02:23 PM
sohcfreak97's Avatar
sohcfreak97 sohcfreak97 is offline
Banned
Re: weird idle
couldn't be a vacuum leak, because it would remain there after he started back up from letting it sit, how many miles? and whats your prev. maint. look like?(did u do all your schedl. maint?)i.e. wires, cap rotor,...but sounds to me like a dirty iac
Old 03-19-2005, 10:34 PM
Re: weird idle
Its has 28 000 miles on it, all maintance has been done, just installed a cold air intake a few weeks ago
Old 03-20-2005, 03:11 AM
Banned
Re: weird idle
Hey...that Might Help.....double Check Everything U Did...sometime My Car Does It After I Diconnect The Battery, Then The Ecu Re-learns Everything And It Stops...but 6 Days Is Kinda Long..
Old 03-20-2005, 07:42 PM
Re: weird idle
I'll give that a try see if it makes a difference, plus i am getting ngk iridium spark plugs so tomorrow when i get a chance to install them hopefully everything goes well.
